Premium vs. Regular unleaded gas - Page 3 - Mercedes-Benz Forum
post #21 of 23 (permalink) Old 09-02-2009, 03:11 PM
Date registered: Jun 2008
Vehicle: 2000 w203 c200k (Yes, it's a w203 from Germany)
Volkswagen Audi Group.
I'm assuming "MAP" is Manifold Absolute Pressure.
Although, in this case, "map" is simply a plotting of points on a graph, connected with lines, and various plots are superimposed onto one graph, leaving a bordered, shaded in region which are the operating parameters and values. When one goes one by one, you might have a plot for 91 octane, with the respective ignition, fuel, knock, and a host of other values. That's one kind of map. Then there could be ones for 87, and ones for 85 and bad gas.
jerk_chicken is offline
post #22 of 23 (permalink) Old 09-02-2009, 03:17 PM
Musikmann's Avatar
Quoted: 5 Post(s)
Thank you very much jerk chicken.
Musikmann is offline
post #23 of 23 (permalink) Old 09-02-2009, 04:58 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Here we go again.
Mapping only goes so far; it can change dynamic timing and injection amount and duration (depending on the design). It can't affect basic design.
When you design a combustion chamber, static valve timing and compression ratios for a specified octane rating, you can throw whatever map you wish into the ECU and it's still not going to compensate for the design "flaw" that presumes a minimum octane. You will still have incomplete combustion, hot spots, deposit accumulation (especially if the injectors are dumping in extra fuel to help compensate, which over time will increase the effective compression ratio, compounding the problem) and increased emissions, which will overwork the cats and O2 sensors.
Really, you can use any justification you like for saving a few bucks at the pump, but it's like trying to convince yourself that if you jump from a second story window into a rose garden you're not going to get scratched. Again, what does the manual say? You can use regular in an emergency, but drive like a grandma and get proper fuel as soon as you can. There are reasons for that, but like I always say, one of the great things about owning a car is getting to decide how to maintain it...or not.
Check Codes is offline
    Regular vs premium gas - Is it a myth? lorryfan W163 M-Class 48 07-19-2011 12:47 PM
    Premium vs Regular Gas BENZ REB W211 E-Class 109 04-05-2010 01:01 AM
    Regular Gas insead of Premium Gas leetec W210 E-Class 46 08-11-2008 11:09 PM
    regular/premium unleaded richri929 General Mercedes-Benz 11 03-03-2008 05:25 PM
    Gas: Regular or Premium? offroadwarrior Off-Topic 18 04-17-2006 10:12 AM
