Wipers gone crazy, control module replacement, help please - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 08-29-2009, 03:52 PM Thread Starter
Date registered: Feb 2009
Vehicle: S500 | 220.175 | 113.960
Greetings community,
2001 S500
Wiper position II and III work fine.
At present time, wipers do a single wipe in position 0 (as if there were set on intermittent) every time I start the ignition.
Now setting I (auto sensing mode) is the one with most problems.
Every now and then, though senses rain quite well, starts to wipe endlessly until something gives up (module/motor?) and wipers stop in the middle of the windshield. To reset, I set to 0, then back on.
So far, I am unable to get a certain answer what may be causing this.
I've checked associated relays and fuses. I've "reset" the auto wiping feature.
Presently, I am trying to find out where it is the control module or the motor which is defective. If its the control module, where is it located?
Thank you all very very much!!
Alex
(Previous post at the W220)
lyoooha is offline
Part # for replacement Seat Control Module dsoelter W203 C-Class 0 07-11-2009 01:49 PM
Climate control gone crazy Fusion.C280 W202 C-Class 3 03-17-2008 05:17 PM
Soft top control module on ebay (3 plug module) StuartKnight R129 SL-Class 0 11-13-2007 06:14 AM
My Climate Control has gone crazy!!! Chupper W124 E,CE,D,TD Class 2 01-11-2004 11:36 AM
Need Advice: Crazy Clmate Control blueeyedmichael W126 S,SE,SEC,SEL,SD,SDL Class 0 08-10-2003 07:02 AM
