front right door control module..please help - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 08-27-2009, 12:23 PM Thread Starter
Date registered: Aug 2009
i drive a 2001 C320, and for the 1st time when i try to adjust the right mirror or electric chair they dont move instead the left ones moves + the right window does some funny stuff when i try to pull it up..im assuming its the front right door control module..now i have never taken the door panel off before n today i looked at it, there wasnt any visible screws..can anyone help me where to start if i want to take the door panel off to get to the module??? any diagrams would be a lota help too
ameraha2004 is offline
post #2 of 2 (permalink) Old 09-03-2009, 07:16 PM
Date registered: Jul 2009
take the triangle speaker off, just pull from the window seal area and slide toward front of car, take a plastic wedge or screw driver(careful) at the lower section of the door grip, not lever to open door, the grip, it has a gap at the lower left under if you look, it comes apart there, two torx upper and lower there, and the srs badge on the panel, pry from the bottom and it snaps off, torx there, remove the trim around the latch on the door, should be a phillips, then the panel should snap off, use a wedge or something flat to get between the panel and door and pull out, the when all are released pull up to remove panel.
c55amgwrench is offline
    door control module... eykeykeyk C208/A208 CLK-Class 18 01-21-2014 07:41 AM
    WTB: W210 Door Control Module Austin814 For Sale/Wanted/Trade/Giveaway 0 08-19-2009 07:25 PM
    does anyone know the part number for a door control module? eykeykeyk C208/A208 CLK-Class 2 04-04-2009 08:28 PM
    Door Control Module location remlucs W220 S-Class 8 08-23-2008 05:10 PM
    door control module ponch W203 C-Class 0 04-12-2008 10:04 PM
