oil change in '05 E500 - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 08-25-2009, 08:52 PM Thread Starter
Date registered: Aug 2009
Sorry guys, new MB owner here with an old and naive question I'm sure:
Anything new or unconventional I need to know about changing oil in an '05 MB E500?
Frankcz is offline
post #2 of 12 (permalink) Old 08-25-2009, 11:02 PM
Kajtek1's Avatar
Quoted: 1227 Post(s)
Nah. The same top mounted oil filter and 15 minutes job with MityVac.
Your car might not have oil dipstick, so check the manual about oil capacity and how to check the level on the dash.
Welcome to the forum.
Kajtek1 is offline
post #3 of 12 (permalink) Old 08-26-2009, 10:04 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Car is designed to have oil vacuumed out. Special tool required.
You can drain from the oil pan drain plug, but you have to remove a LOT of body panels to do so. Plug washers on German cars are ALWAYS replaced NEVER reused.
There is no dipstick.
You should own the service DVD and refer to it before proceeding.
Star Service CDs and DVDs
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #4 of 12 (permalink) Old 08-26-2009, 02:40 PM Thread Starter
Thanks guys. Very useful info. Can I use a manual oil suction pump to remove the oil? (I have one that I use on my boat that slips down the dipstick to pump out the old oil before refilling.)
What oil does the car take? 10w30, synthetic, etc.?
Thanks again,
Frank
Frankcz is offline
post #5 of 12 (permalink) Old 08-26-2009, 03:03 PM
Quoted: 2 Post(s)
Oil MUST meet Mercedes specification 229.5.
Your best bet is Mobil 1 0W-40 European Formula.
This, by the way, does NOT mean any Mobil 1. There are only 2 that meet the specification required, and the other is mostly for diesels and quite a bit harder to find.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #6 of 12 (permalink) Old 08-27-2009, 08:45 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 387 Post(s)
And don't forget that you will need a 'fleece' filter....
keyhole is online now
post #7 of 12 (permalink) Old 08-27-2009, 02:11 PM Thread Starter
a few remaining oil change questions
Thanks guys. Here's what I know so far:
Use Mobil 1 0w40 european style synthetic.
Better to pump the oil out.
Use MB approved filter element.
A few remaining questions if you still don't mind humoring me:
What is a fleece filter?
And is there any problem puming out the oil with an oil pump I use for my boat that sucks the oil through a long tube from the dipstick?
Thanks again,
Frank
Frankcz is offline
post #8 of 12 (permalink) Old 08-27-2009, 03:05 PM
keyhole's Avatar
Quoted: 387 Post(s)
Thanks again,
Frank
If your oil pump works on your boat it should be OK for your car.
Regarding the filter, it's not really made of 'fleece' - its a kind of plastic, but stronger than the traditional paper design. Looks like this:
post #9 of 12 (permalink) Old 08-27-2009, 03:11 PM Thread Starter
Appreciate all of your help.
Great forum!
Regards,
Frank
Frankcz is offline
post #10 of 12 (permalink) Old 08-28-2009, 06:57 AM
keyhole's Avatar
Quoted: 387 Post(s)
Frank - there are some oil change diy with photos on this site, which will work for your engine. I did one here:
http://www.benzworld.org/forums/w209...il-change.html
gregs210 did a better one which you can find in the archives here:
http://www.benzworld.org/forums/w210...change-v6.html
    e500 Grill change bfournier W210 E50 AMG, E55 AMG 1 02-16-2009 09:57 PM
    Help with E500 4matic oil change MB E500 4MATIC W211 E-Class 13 11-06-2008 07:26 AM
    E500 Oil Change Concerns lear31a driver W211 E-Class 51 04-25-2006 10:59 AM
    E500 oil change - 8 liters vs 8 quarts capacity fgwinn W211 E-Class 13 12-24-2005 02:22 PM
    2003 E500 Oil Change flaurino W211 E-Class 7 11-06-2003 06:46 PM
