Rough idle / dying after no use - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 08-23-2009, 11:30 AM Thread Starter
Date registered: Aug 2009
Hello all:
I am sorry if this is a repeat, but I am having trouble searching the forum; I have a 1990 300SE and it normally works very well. The issue is that when the car is not used for 3 - 4 days, the car starts fine, runs fine for 10 minutes or so and then idles very rough - to the point where it will die if I do not keep the RPMs around 1000 in neutral when stopped. The strange thing is that this condition self-corrects after about 30 minutes of use and then the car does will run perfectly - for months - as long as I do not let it sit without use. If I do not use the car for a weekend, it does not have the problem - it must sit from 3 - 4 days for the condition to occur. Thanks for any insight...
JohnnyFos is offline
post #2 of 4 (permalink) Old 08-23-2009, 12:05 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Hi JohnnyFos and welcome to Benzworld.
Your 300SE is what Mercedes calls a W140 and there is a forum devoted to that chassis. Just scroll down from here (General Mercedes-Benz) to the Sedans sub-section and you will see it. This might be something peculiar to the W140 and many more actual owners will see your question there. Good luck.
Musikmann is offline
post #3 of 4 (permalink) Old 08-23-2009, 12:12 PM Thread Starter
Thanks......
Thanks for pointing me to the right forum...................
post #4 of 4 (permalink) Old 08-23-2009, 01:36 PM
Musikmann's Avatar
Quoted: 6 Post(s)
You're welcome
LOL, I'm not so sure I did because it looks like you have a W126 - my bad, but I see you're already getting some help.
260e rough start/rough idle/shudder CaprezMercedes W124 E,CE,D,TD Class 14 05-25-2010 01:36 PM
Low idle, rough idle, stalling, hot and cold start solved: E320/300 rvenerac W124 E,CE,D,TD Class 10 03-22-2010 11:28 PM
ROUGH IDLE, IDLE CONTROL UNIT LOCATION, TIMING & RPM verdejor W126 S,SE,SEC,SEL,SD,SDL Class 16 02-15-2006 10:52 AM
ROUGH IDLE, IDLE CONTROL UNIT LOCATION, TIMING & RPM verdejor General Mercedes-Benz 5 01-22-2006 08:41 PM
diesel idle/dying mhin1956 W126 S,SE,SEC,SEL,SD,SDL Class 1 08-24-2005 03:41 PM
