Ignition Key - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-23-2009, 05:18 AM Thread Starter
Date registered: Aug 2009
Post Ignition Key
I have a 2002 Mercedes Benz G500 Truck and I have noticed that every time I put in the ignition key that it makes a funny noise. I know once you put the key in that it makes a noise but lately it sounds weird. What could be the problem?
FAISONIK is offline
post #2 of 3 (permalink) Old 08-23-2009, 07:01 AM
Musikmann's Avatar
Quoted: 6 Post(s)
My best guess is that is an early warning that something is going bad within the ignition lock cylinder. I would have it properly diagnosed before you and the truck get stranded somewhere because it refuses to start at all.
Alternatively, scroll down from here (General Mercede-Benz) and look for the G-Class forum. This might be somewhat common to your chassis.
Musikmann is offline
post #3 of 3 (permalink) Old 08-23-2009, 03:51 PM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T and others
The system working properly would commuicate with the key and then withdraw the locking bolt, it is the typical noise you hear when inserting the key fob, and withdrawing it. It is hard to diagnoise a noise, go to your MB dealership and ask your service advisor if it is a normal noise. They probably wont charge for that, there is a solenoid that pulls the bolt out of the steering ring...and keeps it out untill the key is removed.
Peter Guenther is offline
    '86 190e Ignition key problem- the key won't turn Guest (MBNZ) W201 190-Class 7 04-13-2010 03:35 PM
    Ignition Key - best way to get a new one? KiwiSlk230 R170 SLK-Class 16 01-18-2010 10:20 AM
    ignition key mary101 General Mercedes-Benz 4 01-03-2008 06:56 AM
    key will not come out of ignition AdamT W140 S-Class 7 08-14-2007 06:11 AM
    Ignition Key YOGGI W202 C-Class 2 06-13-2007 01:52 PM
