2003 C230 Coupe sitting for 8 months needs to pass SMOG - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 08-20-2009, 01:03 PM Thread Starter
Date registered: Aug 2009
I have a 2003 C230 Coupe that has been sitting in my drive way for the past 8 months while I was away on duty. Now I need it to pass Smog in California in order to renew my registration.
I have already changed the oil, and added a full tank of premium gas. Are there any tips or tricks to make sure it will pass smog?
Also, for some reason the gas cap will not line-up and screw on correctly. Any ideas?
Thanks in advance!!!!
loomis28 is offline
post #2 of 2 (permalink) Old 08-20-2009, 01:20 PM
Date registered: Sep 2007
Vehicle: 99 Merc S420 (80k Mi) 07 Lexus LS460 (21k Miles)
I would run techron fuel injector cleaner through the system. If you can't get the gas cap back on, it will set off the CEL (which I assume would be an inspection failure in CA?). You may need to replace it. It could have melted in the sun.
mr.xpowerseller is offline
    Will sitting in a garage for 2 months affect my CLK? shadowhunter C209/A209 CLK-Class 9 09-08-2009 06:46 PM
    Gear change problems after sitting 4-months matei72@gmail.com W210 E-Class 3 02-17-2009 11:37 AM
    Can't pass Smog, can anyone help... carltwo R129 SL-Class 40 02-08-2009 07:13 PM
    Car Sitting for a few Months, now won't start bratwurst W203 C-Class 2 03-14-2008 01:30 PM
    after 4 months of sitting.... rib W123 E,CE,D,CD,TD,TE Class 3 03-14-2005 10:59 AM
