slk230 cuts out at exactly 4000rpms - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 08-17-2009, 11:05 AM Thread Starter
Date registered: Aug 2009
Unhappy slk230 cuts out at exactly 4000rpms
hello everyone,
i another new guy here..with a car problem. ive owned a 88 190E and now a
98 slk230 i loved them both!
i am however having a problem with my slk230 ive taken it two "import specialized" mechanics...they both couldnt figure out whats wrong. the problem being it cuts out, like the fuel shuts off or governs out at 4,000rpms the only engine code i get is is a p0170 fuel trim bank1....which ive got from time to time and ive fixed by cleaning out the MAF. the only other simptom i get is the ignition cycles a little longer to start each time....ive recently changed the O2 sensor and fuel filter...that didnt help.. im told it could be the camp position sensor, the MAP sensor and or fuel pump...but would nt have the mechanics figured that out.....one mechanic did say it was running lean on bank 1 according to the diagnose computer. should i just drive it to the dealer? can anyone advise?
stewie is offline
post #2 of 7 (permalink) Old 08-17-2009, 12:44 PM
Supporting Vendor
FCP Euro's Avatar
Date registered: Jul 2008
Quoted: 22 Post(s)
How old are you spark plugs? I had this same problem on my volvo, changed out the plugs and the miss went away.
Quality & Service, Guaranteed for Life
FCP Euro - OEM & Genuine European Auto Parts Online
FCP Euro is offline
post #3 of 7 (permalink) Old 08-17-2009, 05:13 PM Thread Starter
the first mechanic i took it to told me they changed them....but i better check for myself thanks for the suggestion
stewie is offline
post #4 of 7 (permalink) Old 08-17-2009, 06:04 PM
ohlord's Avatar
Vehicle: 1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
Quoted: 5 Post(s)
Cuts
out while in motion or cuts out while revving it in park or neutral?
If so in park or neutral it is your neutral safety rev limiter. Most Mb models have them separate of the electronically limited top speed governor.
So clarify when it occurs.
00-02 drivers side self dimming heated mirror
17mm special spark boot tool
O2 plug and play sensors
16mm spring loaded swivel spark socket
trans dipstick and magnet
Mercedes Benz Lyrics
Artist(Band):Janis Joplin
"Oh Lord, won't you buy me
a Mercedes Benz"
ohlord
"Follow Peace,center Life"
ohlord is offline
post #5 of 7 (permalink) Old 08-18-2009, 11:35 AM Thread Starter
i checked the plugs there good...to clarify it cuts out at 4k in P, N and while driving.... no matter what i do, shift down, punch, and or ease it up to 4k in any and all gears. its like some is playin a prank on me and lowered the governor to 4k. i just ordered a mew MAF (even though i clean mine regularly) and the starting cycle is runs longer than usual which makes me wonder about the crank sensor and or the cam sensor...but would i get an engine code aside of the P0170?
stewie is offline
post #6 of 7 (permalink) Old 08-18-2009, 03:13 PM
Date registered: Jul 2006
Vehicle: Mercedes SLK 230K Special Edition
Send a message via Skype™ to Crllsn
i had it once for 10 mins was cos of abs sensor misfunction probably water got in and out... it was stored as canbus error
Crllsn is offline
post #7 of 7 (permalink) Old 08-29-2009, 03:26 PM Thread Starter
is there a way for me to test the abs speed sensors?
well just picked up from a second mechanic...also told me to take it the dealer...i dont know if i dare drive it 150miles with its current problem.
does anyone if and where the rev limiter is on the mighty slk230?
stewie is offline
    Cuts out randomly Chris A R170 SLK-Class 111 07-21-2010 10:07 AM
    CAR CUTS OFF NESS925 W220 S-Class 1 08-07-2007 04:49 AM
    A/C cuts off?? smoothcoat R171 SLK-Class 2 06-05-2005 01:38 PM
    SLK230 starts and runs fine for 5-10mins then it cuts off and will not restart - plz read more below sealluke General Mercedes-Benz 3 10-15-2004 09:47 PM
    AC Cuts Off... jamminjames W126 S,SE,SEC,SEL,SD,SDL Class 1 06-08-2004 03:15 PM
