Mid 1980's 300 turbo and 350 turbo - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 08-17-2009, 07:23 AM Thread Starter
Date registered: Aug 2009
Vehicle: 1986 300SDL (2) 1981 300SD
Post Mid 1980's 300 turbo and 350 turbo
Hi ;
Two things I learned after just buying a 1986 300 SDL about this engine and the 350:
300: Probably most people know that the heads can warp or crack when the engine is overheated. There is a production code of "14" on the head itself on digits 7&8 on the original heads. Replacement heads fix this problem and can be as high as "22" in the same digits. Basically, if the car overheats, pull it over as immediately as possible. Alternatives would be to put the heater on full fan and power back the engine as much as possible.
350: These sometimes have a problem of oil consumption and the cylinders "ovalling" which is a very bad situation. The dealer I bought my 300 from told me this (AFTER I bought the car). The original 350 engine had a head gasket that can compress. I don't know how often this occurs. I am told from rarely up to 50% of the 350 engines. If this happens there is a clearance problem. Then there is excessive oil consumption, rods bend and the cylinder ovalling occurs. I don't know if the order of these event is correct.
To fix this there is a replacement gasket which fixes the problem altogether. Cars that have had this done have a red dot on the head. I don't know how much this costs, but a lot cheaper than the alternative. If you have a car with the 350 engine without the red dot, either get the gasket replaced or watch the oil comsumption carefully. If it starts eating oil, change the gasket right away. Maybe it is better to just get the gasket replaced anyways.
Don Blair is offline
post #2 of 2 (permalink) Old 08-17-2009, 01:46 PM
Date registered: Oct 2007
Vehicle: 2002 SLK 230 1986 560SL 2008 Honda CRV
Welcome to Benzworld
livefreeordie is offline
    Which diesel model is better? 240 or 300 or 300 turbo? eso7 W123 E,CE,D,CD,TD,TE Class 22 05-17-2010 07:15 PM
    FS: 1991 350 SD Turbo Kalifornia W126 S,SE,SEC,SEL,SD,SDL Class 4 08-05-2008 04:32 PM
    Turbo Charging A 300 E With Turbo Diesel Parts 4liter W124 E,CE,D,TD Class 22 12-05-2006 10:18 PM
    300 Turbo or non-turbo, that is the question GEM W123 E,CE,D,CD,TD,TE Class 13 11-10-2006 02:54 AM
    '91 350 SD Turbo Value jrehm W126 S,SE,SEC,SEL,SD,SDL Class 4 07-08-2005 05:45 AM
