MB CAN do or don't - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 08-16-2009, 10:50 PM Thread Starter
Date registered: Feb 2006
Vehicle: 1999 ML320
Quoted: 310 Post(s)
MB CAN do or don't
Could this be the root cause ?
The protocol sounds like a mess.
On Mercedes cars, CAN wiring has been incorporated since 1992 to allow the sharing of information that is used for the engine, transmission, airbag, anti-lock brakes and suspension control systems. Mercedes uses a two-wire system, which allows two data streams. One handles communication for the primary modules for major components like the engine (PCM), transmission (ETC), ABS, ESP (electronic stability protection) and ASR (acceleration slip reduction), and other systems designed to protect the driver against making bad driving decisions. The other wire is used to connect accessory systems such as locks, windows, HVAC and even the audio system. That second wire also is supposed to provide a backup path if the main or primary control wire is damaged.
Since these systems were first integrated into wiring harnesses, the ability of the controllers and control units to handle more information at faster speeds has made reliability a problem. With each increase in data transfer protocol, or bandwidth, the integrity of the wiring has been the limiting factor for reliable and efficient operation.
Since the system uses digital technology, even a small hiccup will cause miscommunication, false signals and fault codes. This is probably why we see code descriptions like “implausible.” The processors (See Photo 1) are taking in and distributing information that has been interrupted or misinterpreted by another module or controller. These CAN signals are also prioritized depending on whether the information is needed by the master control module (Mercedes calls this the HFM-SFI module). Wiring and connector condition becomes a problem at even lower mileages than has been typical of Mercedes cars.
Mercedes 'CAN' Diagnostics ? Uncovering Faults Speeds The Repair Process ...
... and this important discussion continues.
mlfun is offline
