E320 NO BRAKE LIGHTS. HELP! - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 08-15-2009, 06:49 PM Thread Starter
Date registered: Aug 2009
Question E320 NO BRAKE LIGHTS. HELP!
i checked the light bulbs and the fuse, they were good. i replaced the brake switch too. i also looked at the wires. do u have any suggestions?
rydinfly is offline
post #2 of 4 (permalink) Old 08-16-2009, 09:27 AM
Musikmann's Avatar
Quoted: 6 Post(s)
Check the sockets. If you have a W210 (1997-2002) those are a known issue. You should be able to clean the contacts with a fine grit sandpaper. There might be other methods too. Check the sticky threads in the W210 forum. Just scroll down from this General forum and look under Sedans. Good luck and welcome to the forum.
Musikmann is offline
post #3 of 4 (permalink) Old 08-16-2009, 09:42 AM
Kajtek1's Avatar
Quoted: 1168 Post(s)
From what I remember fixing my W123, the problem was friction clutch that pushes the digits. I consider it unrepairable.
Kajtek1 is online now
post #4 of 4 (permalink) Old 08-16-2009, 02:11 PM Thread Starter
Exclamation halfway there....
i got the 2 rear brake lights working. the third brake light on the rear panel still doesnt work. the bulb is fine and the contacts are fine. if a relay is faulty, can it still work for one thing it controls and not another? for example, if it controls the front and the rear and it stopped working for the rear can it still work for the front? im still trobleshooting the rear inner lights which are faulty. the reverse lights still work, as well as the license plate lights. any ideas?
rydinfly is offline
    ABS/BAS-ESP lights on - Brake lights don't work niwred W210 E-Class 12 11-27-2013 04:53 AM
    95 E320 stalled brake lights not working alemlsl W124 E,CE,D,TD Class 24 03-08-2010 09:03 PM
    My Rear brake lights and 3rd brake lamp stay on all the time! mclasser W163 M-Class 1 09-16-2006 05:17 PM
    SLK R171 Tail Lights and Centre Brake Lights for Sale slkfans For Sale/Wanted/Trade/Giveaway 0 01-22-2006 11:20 AM
    Brake lights on 94 E320 Wagon don't work Guest (MBNZ) W124 E,CE,D,TD Class 2 03-02-2002 08:58 AM
