240D Odometer - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 08-15-2009, 11:49 AM Thread Starter
Date registered: Aug 2009
Post 240D Odometer
I have an 83 240D and the odometer has quit. I have a 2nd instrument cluster, that is meant to work - but the miles on the new cluster is 67K and there are 147K on the car. I'd like to set the new instrument cluster odometer to 147K - I don't want to scam anyone.
Any ideas??????
jns747 is offline
post #2 of 7 (permalink) Old 08-15-2009, 03:34 PM
~BANNED~
Date registered: Sep 2007
Vehicle: 99 Merc S420 (80k Mi) 07 Lexus LS460 (21k Miles)
Rebuild the existing odometer using the gears from the good one.
mr.xpowerseller is offline
post #3 of 7 (permalink) Old 08-15-2009, 07:21 PM
Kajtek1's Avatar
Quoted: 1197 Post(s)
I've been rotating those mechanical odometers both ways. Even had couple spares, but dispose them couple years ago. (4 years after I sold W123).
However it is easy to damage the odometer if you are not too carefull, so another way is to take a picture of both odometers with current newspaper in the back and just install the good one keeping the record of mileage change.
Kajtek1 is offline
post #4 of 7 (permalink) Old 08-16-2009, 09:08 AM
Date registered: Jan 2004
Quoted: 30 Post(s)
Common problem on these odometers. Once you have the odometer out, you've done the hard part. I'd just fix it. All you have to do generally is roughen up the shaft that the gear that slips rides on. There is no guarantee that the other odometer will work or last any longer than the one you can easily fix.
Len
'59 220S Cabriolet - for sale - http://www.mbzponton.org/mbz220s/sellswap/car4sale.htm
'83 240D original owner 351,500 miles - for sale - http://www.benzworld.org/forums/w123...g-my-240d.html
'88 560SL 41,000 miles being parted out - https://sites.google.com/site/mercedesstuff/home
'99 E300 turbo 196,000 miles
'03 SLK320 34,500 miles
'14 Smart electric
sokoloff is offline
post #5 of 7 (permalink) Old 08-17-2009, 09:56 AM
Diesel giant has a great repair page. How to Repair Your Broken Odometer
I think perfomance products sells the replacement gears. I saw them in the calalog but I can't find them on the website.
Advice for anyone driving an older MBZ. Do not reset your odometer while moving. Sometimes it causes the old gears to break.
scamandin is offline
post #6 of 7 (permalink) Old 08-17-2009, 09:59 AM
Found the gear page. Search for Mercedes® Speedo Repair Gears if the link doesn't work.
post #7 of 7 (permalink) Old 10-23-2009, 11:57 PM Thread Starter
thanks to all
I took out the unit and opened up the back and glued the spindal gear on and now it works. But what a hassle...
jns747 is offline
    Odometer Damper Spring Fix (for correct odometer reading) raed_jan W201 190-Class 0 06-20-2009 08:26 PM
    digital odometer and trip odometer no longer illuminate S320_on_18s W140 S-Class 3 05-27-2008 08:14 PM
    83 240D speedo/odometer - Question Leeyore W123 E,CE,D,CD,TD,TE Class 4 08-09-2006 07:01 PM
    Odometer/trip odometer stopped working theratpatrol R/C107 SL/SLC Class 8 07-23-2005 09:12 PM
    Broken Odometer on 240D BiodieselCleveland W123 E,CE,D,CD,TD,TE Class 3 05-13-2004 05:59 AM
