glow plug warning light coming back on - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-12-2009, 11:40 AM Thread Starter
Date registered: Jul 2009
Vehicle: 2001 C220 CDi Elegance MANUAL
Unhappy glow plug warning light coming back on
im hoping someone can help me out here. after starting mt 1999 w210 E300 Turbodiesel, the glow plug light comes back on for a few minutes then goes out. the plugs have been checked for resistance and two that were useless were replaced. ive re checked the resistance through them and although my meter isnt reading quite correct with its readings, the resistances were as near identical as possible! not sure what to check out next as its not a problem ive ever come across before! also, i cant see that it would make a difference, but its a UK car. all help gratefully recieved!
turbopete is offline
post #2 of 3 (permalink) Old 08-13-2009, 08:42 AM
Date registered: Jan 2004
Quoted: 34 Post(s)
This comment bothers me a bit - "my meter isnt reading quite correct with its readings."
My bet is still on a bad glow plug or two. Did you replace the bad ones with Bosch or Beru plugs. Did they ever work properly after the fix?
Len
'59 220S Cabriolet - for sale - http://www.bruceadams190sl.com/1959-...20s-cabriolet/
'83 240D original owner 351,500 miles - sadly I let it go
'88 560SL 41,000 miles being parted out - https://sites.google.com/site/mercedesstuff/home
'99 E300 turbo 207,000 miles
'03 SLK320 37,500 miles
'14 Smart electric 10,500 miles
sokoloff is offline
post #3 of 3 (permalink) Old 08-13-2009, 01:56 PM Thread Starter
meter had a loose connection in a cable. fixed now. plugs fitted were ngk, as were the rest that worked. the fault on the light must have been a bad connection on the wiring to the relay as i unplugged the wiring to check the resistances, all were ok as explained, refitted plug, went to start car and problem had gone!
Glow plug light is not coming on.... LDesign W123 E,CE,D,CD,TD,TE Class 3 08-19-2008 04:01 PM
glow plug light not coming on!! turbodieselguy W123 E,CE,D,CD,TD,TE Class 16 04-05-2007 11:15 PM
Glow Plug Light coming on RusML270 W163 M-Class 4 12-27-2006 01:55 PM
glow plug light not coming on!! turbodieselguy W123 E,CE,D,CD,TD,TE Class 2 12-08-2006 10:28 AM
glow plug warning light rufflesurf V-Class 2 10-17-2005 09:06 AM
