ignition lock will not turn - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 08-09-2009, 04:23 AM Thread Starter
Date registered: Aug 2009
Hi .
I know this has been asked many times ,but was wondering if someone could just clarify one point?
The barrel with the key in will not trun
The silver cover over the barrel will rotate so i can get a rod down either side but i assume from reading on the forum that the barrel must turn as well to release not just this cover ?
Any help would be much appreciated
Thanks
johnnybg is offline
post #2 of 5 (permalink) Old 08-09-2009, 05:43 AM
Diesel Benz's Avatar
Quoted: 35 Post(s)
Originally Posted by johnnybg View Post
Hi .
Thanks
Current IR keys are completely different from the older keys, and there are a few in-between. I guess you are talking about an old mechanical key which does not turn because the ignition slot and the key are worn out.
Diesel Benz is offline
post #3 of 5 (permalink) Old 08-09-2009, 05:45 AM
Date registered: Aug 2006
Vehicle: 1992 300CE
hold the steering wheel, it must be on lock
ronald7410 is offline
post #4 of 5 (permalink) Old 08-09-2009, 05:46 AM
Vehicle: 1992 300CE
Diesel could also be right, and youd have to pay for a new ignition
post #5 of 5 (permalink) Old 08-09-2009, 08:53 AM
Kajtek1's Avatar
Quoted: 1166 Post(s)
Knowing MY would be very helpful.
Kajtek1 is offline
    Steering lock stuck on? Or ignition lock?.....help! busters the boy! W124 E,CE,D,TD Class 21 05-12-2013 09:09 PM
    Passenger lock, Console lock won't turn pbassett2223 W126 S,SE,SEC,SEL,SD,SDL Class 1 11-14-2007 08:11 AM
    ignition lock cylinder & ignition switch lakeside W164 M-Class 2 07-23-2007 06:55 PM
    Ignition lock ErwinHock G-Class 44 12-28-2006 05:07 AM
    2000 G500; Key won't turn ignition lock AG-wagen G-Class 10 02-02-2006 05:56 PM
