300SD Engine Swap - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 08-07-2009, 11:19 AM Thread Starter
Date registered: Aug 2009
Exclamation 300SD Engine Swap
I currently have a 1983 300SD with a perfectly running motor but a horrible body on it.
I found a (what the owner claims to be) a 77 300SD without a motor, but amazing interior and a body with only a small amount of rust.
Will the motor from the 83 fit in the 77 without any adjustments?
They are both 300SD but I believe the 77 is a different body style than that of the W126 on the 83.
Any help?
DJ AUNS is offline
    1982 300SD Engine/Trans swap into a 1987 300SDL? jusme W126 S,SE,SEC,SEL,SD,SDL Class 5 12-24-2009 03:39 PM
    Engine swap: 280SE with a 300SD engine? stumptown_dan W116 S, SE, SEL, SD Class 3 12-06-2007 09:47 PM
    82 300SD (turbo diesel) engine swap dodgetkboy78 W126 S,SE,SEC,SEL,SD,SDL Class 1 09-12-2005 02:49 AM
    300SD engine swap PrinceGeorges W126 S,SE,SEC,SEL,SD,SDL Class 2 06-04-2003 05:17 AM
    300TD / 300SD motor swap paul6469 W123 E,CE,D,CD,TD,TE Class 2 02-27-2003 05:56 AM
