W202 Internal Rear View Mirror Disassembly - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-07-2009, 06:18 AM Thread Starter
Date registered: Oct 2007
Vehicle: 1994 C180 Engine with 1995 Chassis PMS Engine 38 Pin OBD
Hi Folks, I've finally found THE rattle. '95 C180 Manual. Previously had the radio and A/C out, tied up everything under the dash, lifted carpets and cable tied everything, even had the trim off from the windscreen pillars & cable tied them too. The rattle is actually emanating from the rear view mirror. Managed to get it off the ceiling, massive spring in there ! What I need to find out is how to separate the mirror glass from the plastic backing which holds the immobilser etc. This mirror has the red & green indicators on the front & rear sides. Took the car to MB yesterday and they said the two pieces could not be separated. I've tried squeezing and prodding with a thin bladed jewellers screwdriver but don't want to damage the thing. Any ideas before I drill a tiny hole in it and squirt some Sista Foam inside. ( This stuff expands to fill any cavity !! ) Holding thumbs.
Bernard Rother is offline
post #2 of 3 (permalink) Old 08-17-2009, 11:16 AM
Date registered: Aug 2009
Vehicle: Mercedes C180 - Year 1999
Did you have any luck with your rear view mirror? How easy is it to remove the mirror itself?
lukejr is offline
post #3 of 3 (permalink) Old 09-06-2009, 11:15 PM Thread Starter
Hi, no luck so far. Been thinking about it & will probably use a Dremel & fine bit to drill a hole in the left & right side side & squirt some Tectyl wax onto the bottom of the mirror .. hopefully that's where the loose bit is sitting. When the wax dries maybe it will hold the part somewhat. Will update as thing transpire.
    Outside rear view mirror...exploded view? 1998_S500 W140 S-Class 9 02-03-2013 10:38 AM
    rear view mirror disassembly lander91 W126 S,SE,SEC,SEL,SD,SDL Class 2 11-28-2006 01:23 AM
    WANTED: W123 right side view mirror internal part ducatipaso For Sale/Wanted/Trade/Giveaway 7 08-08-2006 01:29 PM
    Inside Rear View Mirror Internal Laminating??? habanero69 R170 SLK-Class 1 08-16-2002 09:42 AM
    SLK 32 Pass. r.view mirror disassembly Shane R170 SLK-Class 1 03-11-2002 12:25 PM
