C230K 2003 fuel guage - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-05-2009, 06:14 PM Thread Starter
Date registered: Aug 2009
Arrow C230K 2003 fuel guage
i have a 2003 C230K and my fuel gauge isn't working. it's on E but i know i have half a tank left. Can anyone suggest what to do.
it's been 3 days already
familyjoke is offline
post #2 of 3 (permalink) Old 08-05-2009, 06:24 PM
Musikmann's Avatar
Quoted: 5 Post(s)
Your car has a fuel level sending unit (sensor if you prefer) and it is somewhere in the fuel tank. On some cars this is a difficult job to replace, but I don't know about yours. Try asking about this on the W203 forum where the actual owners hang out.
Musikmann is offline
post #3 of 3 (permalink) Old 08-06-2009, 09:24 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 343 Post(s)
Keep your eye on the odometer and make sure that your tank is kept over half full, judging by your normal fuel consumption. Do you have a 'Range' display at the cluster?
Meanwhile get your codes read with an OBD2 reader. According to my files the tank level fault codes are these:
P0460 Fuel Level Sensor Circuit Malfunction
P0461 Fuel Level Sensor Circuit Range/Performance
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel Level Sensor Circuit High Input
However, your C230K has a tank divided into 2 halves, each of which has a level sensor. I have no idea how you know which one has failed...
To reach them is no fun. To get access you must remove the rear seat & covers. Then unscrew a very large nut in the tank (special tool reqd here) before you can remove either sensor. Not a job for the faint-hearted!
Of course it might be a fault on your display. If they are plasma, there are stories of ribbon cable connector problems. Look up cluster faults in the archives using the 'search' facility ^^^.
Oh, and welcome to the forum. Use the UserCP ^^^ to include some details of your car and your location, as it sometimes helps. And as MM says above - you have a forum just for your MB model.
keyhole is online now
    2003 C230 gas guage inop today! jj2828 W203 C-Class 10 08-10-2008 10:40 PM
    New fuel guage, does this seem right? Nascar Fan R/C107 SL/SLC Class 5 07-18-2007 05:21 PM
    fuel guage jonny5quest W123 E,CE,D,CD,TD,TE Class 1 06-30-2005 06:44 AM
    no movement on temp guage and fuel guage rr_havuz W202 C-Class 6 12-31-2003 07:12 PM
    Fuel guage... Guest (MBNZ) W203 C-Class 3 11-19-2001 03:43 AM
