Temperature Gauge question - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 08-04-2009, 12:36 PM Thread Starter
Date registered: Jul 2009
Vehicle: 2002 C320W
I am a fairly new MB owner (2002 C320) ....my question is where is the tempurature gauge on the darn thing? On my screen that has the clock on it which is down on the right side...on the left side it has a +88 ...is that the outside temperature reading? The reason I am asking is I was driving today on the highway and saw it go up to +140 and then drop down back to +102 within 3-4 minutes...I do live in Houston Tx and it is very hot here now but not +140 degrees....SO I started wondering if this was in fact a bad thing ....was the car running hot ...etc...SO how can you tell what the engine temp is....or is this it...
Thanks for the replys in advance...
SOUNDGOD is offline
post #2 of 2 (permalink) Old 08-04-2009, 07:47 PM
Date registered: Aug 2007
Vehicle: 2006 C230 Sport
I'm not sure about 2002, but on my 2006 the coolant temp gauge is in degrees Celsius, and usually reads ~90. I'd definitely check the cooling system. Could be low coolant, but more likely a stuck thermostat.
Geezer1 is offline
    Temperature gauge, Fuel gauge, Speedometer and Tachometer are all Dead tim995785 W210 E-Class 17 03-24-2016 02:08 PM
    95 E320 temperature gauge/thermostat question manditrame General Mercedes-Benz 0 08-21-2008 08:47 PM
    Temperature gauge, Fuel gauge, Speedometer and Tachometer are all Dead tim995785 W124 E,CE,D,TD Class 1 05-04-2008 03:17 PM
    temperature gauge question benzcouple W210 E-Class 0 02-11-2008 10:38 PM
    Outside temperature gauge Guest (MBNZ) W124 E,CE,D,TD Class 0 04-25-2002 01:43 PM
