help needed C230 coil spring - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 07-28-2009, 12:12 PM Thread Starter
Date registered: Jul 2009
my 2002 c230 coupe's front left coil spring just broke and others are about to as well. I'm consider the trade off of installing OEM coil springs or performance lowering coil spring (e.g. Eibach or H&R). Here are my concerns.
1) someone tells me if I choose Eibach or H&R, I need to adjust/replace some other parts as well. Which parts are those? are those necessary? what if I just install Eibach or H&R w/o those? are harm to the car?
2) Is Eibach better compared H&R? I check in the forum, most people think Eibach gives a better ride but lowered both front and rear the same level, where H&R does a little better by lowering rear less.
3) can I install the OEM ones myself and where can I get them? MBdealership?
Thanks a lot
Dave
DavePW is offline
Coil Spring Question jordanhoff W201 190-Class 5 03-06-2009 05:47 PM
Need a coil spring compressor ScottinSoCal R/C107 SL/SLC Class 11 08-20-2008 02:10 PM
Part # A0004640318 'reed coil' 'spring coil' pokdub General Mercedes-Benz 4 02-02-2008 05:42 PM
What's the weight of a coil spring? Rollingstone W126 S,SE,SEC,SEL,SD,SDL Class 7 07-15-2007 09:30 AM
front coil spring ewan69 V-Class 0 04-09-2007 04:32 AM
