1992 300e cruise engages but invariably shuts off like the brake was touched?? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 07-28-2009, 10:34 AM Thread Starter
triggerhorse's Avatar
Date registered: Feb 2009
Vehicle: 1993 500SEL
Unhappy 1992 300e cruise engages but invariably shuts off like the brake was touched??
Hi!- from Chilliwack----Had a Suspension/ Exhaust inspection. I was told the driver side front has a blown ball joint and he wants $100 to fix if I get the part for him.
More importantly, During the inspection he used a second lift while on the hoist. The next time I used the cruise (3hrs later) it engaged, but for no particular reason, in a few seconds, it shut off just like the brake was touched. It will stay engaged for various amounts of time up to maybe 5-10 seconds max. When I use it to accelerate it works fine, but still disengages soon after the speed is set. It does this at all speeds. What do you suggest?
triggerhorse is offline
post #2 of 2 (permalink) Old 07-28-2009, 01:38 PM
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280 '11 GLK350
Typically, it's either the cruise control actuator (mounted on engine beneath the intake) or the control module (inside cabin under front passenger carpet) that is the culprit.
Other suspects are stretched speedometer cable or malfunctioning brake light.
MTI is offline
    1992 300E transmission in a 1993 300E 2.8 M104 engine? abiez W124 E,CE,D,TD Class 2 03-17-2009 10:17 AM
    Sex invariably spells trouble, says Dalai Lama Jakarta Expat Off-Topic 0 11-29-2008 07:24 AM
    1988 300e shuts off when i stop bige864 W124 E,CE,D,TD Class 1 10-04-2008 02:04 PM
    high pitch whistling sound, stops when brake pedal is touched mrutkow2 W163 M-Class 7 11-07-2006 05:40 AM
    1992 300E cruise control John WH W124 E,CE,D,TD Class 2 02-28-2005 08:48 PM
