Simple question but not so simple answer... - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 07-26-2009, 01:28 PM Thread Starter
Date registered: May 2009
I've got a 2004 c240. Although there isn't a PCV valve there is a valve like stem that is in between two tubes that come from the PCV inlet hose area. If you don't know exactly where I'm speaking of, let me explain...
You've got the L shaped tube that is between the throttle position sensor (which is attached to the throttle actuator) and the MAF. Stemming from the L shaped tube, there is a *inlet hose* which leads to or from perhaps the breather boxes. I CANNOT seem to get the tubes off of that valve like thingy that I'm speaking of. Can anyone give me any advice on how they've gotten tubes off of ANYTHING that they were having problems with? Thanks!!
Perhaps cutting them and getting new ones???
enap66 is offline
post #2 of 2 (permalink) Old 07-27-2009, 04:33 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 341 Post(s)
Hi enap
Would you like to use the UserCP ^^^ and add some details about your location & ride. Also you have your own forum here where all C240 discussions are listed.
From this WIS diagram - is your question about item 8? I think that it just pulls off. Maybe if it has 'hardened' you will have to cut it off. Buy the replacement first!
Name:	C240 c-head.jpg
keyhole is online now
    Simple answer to hopefully a simple question please 560 ahoy W126 S,SE,SEC,SEL,SD,SDL Class 7 04-30-2009 05:41 PM
    Simple Answer? evster5 R171 SLK-Class 2 04-18-2006 08:13 AM
    Simple Yes No Question Scottgs G-Class 4 12-24-2005 10:37 AM
    Need answer to a simple question fast Geeky1 W126 S,SE,SEC,SEL,SD,SDL Class 4 11-02-2004 11:02 AM
    just need a simple answer... RaVer R170 SLK-Class 5 12-09-2001 04:05 PM
