brake light on dash - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 07-26-2009, 11:30 AM Thread Starter
Date registered: Jul 2009
Vehicle: 1991 300sel
Cool brake light on dash
I have a 91 300sel and the brake light is on in the dash. The e brake is off and hitting the switch, the fluid level is good but there is a leak in a rear brake line. What does the light indicate?. Rich
onetwothreebenzs is offline
post #2 of 4 (permalink) Old 07-26-2009, 02:48 PM
Date registered: Feb 2008
Vehicle: 2004 W220 (S430) ; 2001 R129 (SL500) Sport
Location: Alabama Gulf Coast--formerly Charlottesville, VA
Could be pads need replacing. Could be the leak in the brake line is reducing line pressure below safe levels. Could be a bad switch at the e-brake. Could be a fault somewhere in the brake sensor system.
I'd bet on brake pads, but a car that old could have a fault in the brake sensor system due to age. Connections corrode, insulation gets brittle and breaks, wires break from flex.
Good luck finding the gremlin.
"Don't pick a fight with an old man. If he is too old to fight, he'll just kill you."--John Steinbeck
DrJfrmLA is offline
post #3 of 4 (permalink) Old 07-26-2009, 11:22 PM
Diesel Benz's Avatar
Quoted: 35 Post(s)
While the brake line is leaking, the the warning light is a minor issue because you should not drive the car before the brake line leak is fixed. Once done, the advice above should be a good start to figure out the rest.
Diesel Benz is offline
post #4 of 4 (permalink) Old 07-27-2009, 10:52 AM
Date registered: Jan 2004
Quoted: 30 Post(s)
I assume you are talking about the red brake light and not the amber one. Red brake light means your parking brake is on or that your brake fluid in the reservoir is low. There are two chambers in the reservoir. If you have a leak, it is likely that the chamber for the rear brakes may indeed be low regardless of what you think you saw. But as mentioned above, why would you even drive such a dangerous car?
Len
'59 220S Cabriolet - for sale - http://www.mbzponton.org/mbz220s/sellswap/car4sale.htm
'83 240D original owner 351,500 miles - for sale - http://www.benzworld.org/forums/w123...g-my-240d.html
'88 560SL 41,000 miles being parted out - https://sites.google.com/site/mercedesstuff/home
'99 E300 turbo 196,000 miles
'03 SLK320 34,500 miles
'14 Smart electric
sokoloff is offline
    Brake warning light on dash ... cause ?? TJ R170 SLK-Class 4 08-25-2009 11:00 AM
    '83 300SD Brake light on dash cluster Surfin' Elvis W126 S,SE,SEC,SEL,SD,SDL Class 1 10-27-2007 07:49 PM
    Dash brake light question dentate gyrus W123 E,CE,D,CD,TD,TE Class 5 10-14-2007 11:31 PM
    Dash brake light and pad light comes on and beeping rcltrh W163 M-Class 4 05-21-2006 04:45 PM
    Question about the brake sensor light on the dash... rainier W163 M-Class 2 01-22-2003 11:02 PM
