ML320 (2000 model) failed to run on first startup - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 07-26-2009, 10:06 AM Thread Starter
Date registered: Jul 2009
Question ML320 failed to run after startup
Greetings All,
First attempt to turn on the engine of my ML320 2000 model, it turned over but fails to run. If I turned off the engine and try starting it one more time, the car runs fine.
It has become a routine to turn off and turn on in order to get the car to run.
BTW, the Crankshaft Positioning Sensor was replaced about a year ago after I had another startup problem. Also, Auto Zone confirmed the car battery is fine.
Any suggestions to help understand the cause and how to remedy the problem will be appreciated.
Thanks for your anticipated response.
AC.
abichannel is offline
    98 ML320, won't run after battery change tim66 W163 M-Class 14 11-16-2008 03:41 AM
    ML failed to shift to 5th gear (2000 ML 430) cal45fan W163 M-Class 3 02-11-2007 09:36 PM
    Side Steps Ml320 2000 Model W163 Vaio W163 M-Class 15 10-13-2005 11:01 AM
    Parts cd Problem trying to run on pro 2000 Gerald A G-Class 15 03-25-2005 07:48 AM
    Does anyone have CLK poduction run #s by model and year? shell C208/A208 CLK-Class 1 02-15-2002 08:13 PM
