Power from an ignition keyhole for CD player on C180?(Have WIS) - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 07-22-2009, 06:26 AM Thread Starter
Date registered: Jul 2009
Vehicle: C180 W202
Hi,
I need to take power (+ pole) from ignition keyhole for my CD player. Can anyone help me with this or direct me where to in WIS.
djol is offline
post #2 of 4 (permalink) Old 07-22-2009, 07:27 AM
Diesel Benz's Avatar
Quoted: 40 Post(s)
Originally Posted by djol View Post
Hi,
You should add your car details to your profile. From another post I can figure out it should be a 202 but a C180 could be a W203 or a W204 too.
I don't think you should grab wires to the ignition switch. You should find a fused wire with a sufficiently small fuse, you could add a CD player fuse on top.
By the way, do you mean a separate CD player/changer or a new radio with a CD player? What's wrong with the existing radio wiring harness?
For a 1995 W202 WIS isn't perfect, you may try this diagram instead:
http://www.autolib.diakom.ru/CAR/Mer...GRAMS/5312.pdf
Diesel Benz is offline
post #3 of 4 (permalink) Old 07-22-2009, 08:29 AM Thread Starter
Vehicle: C180 W202
It´s W202 since it´s made in 1995.
I´m wiring my TM-715QL LCD monitor, but it´s all the same for CD player too. I have red wire which goes on ignition and yellow which goes on direct fused 12DC, also I have black wire which goes on ground.
So, where should I hook up red wire which goes on ignition?
Thanks
djol is offline
post #4 of 4 (permalink) Old 07-22-2009, 11:04 AM
Quoted: 40 Post(s)
Thanks
If the referred wiring diagram is right, then you should have a pink/yellow/green (odd colours though) wire at the car that is intended to provide switched power via ignition switch to the radio. Looks like there is no permanent power, you should find another source for that.
Power from an ignition keyhole for CD player?(Have WIS) djol W202 C-Class 5 07-22-2009 11:02 AM
2001 c180 classic ignition barrel writ3r W203 C-Class 0 04-27-2008 10:46 PM
Ignition Lead Replacement (Apr 1994 C180) pmerrill W202 C-Class 3 02-14-2008 03:01 AM
1994 c180 power gains? punksnut W202 C-Class 3 07-26-2005 03:10 AM
MY02 power folding mirror problem -- anybody got the WIS? bkerkhof W163 M-Class 3 03-26-2005 10:15 AM
