1994 C180 cold engine problems - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 07-21-2009, 04:13 PM Thread Starter
Date registered: Jul 2009
Hi I have had the car about 2 weeks and have a problem I am hoping the forum can help with. When started from cold I need to push the throttle down to get it to start it runs a bit lumpy and has almost no power. Using the throttle normally makes things worse I move the car with no throttle but at a snails pace. Once it has warmed up it is a lot better but I still think lacks power. driving at 80mph it is fine. I have changed the following.
Plugs (the old ones looked OK)
air cleaner
Sealed a gap in the air duct from the filter to the inlet manifold.
Soldered the connections on the OVP relay
All the vacuum connections and pipes look to be OK and are in place.
The auto box also is a bit rough shifting.
There is no MAF but a temp sensor in the air duct. I have cleaned it with IPA spray but not replaced it.
Any advice greatfully received.
Many thanks Dave
daveseavista is offline
    C180 1994 - Central Locking, grizzly_b W202 C-Class 2 07-14-2009 01:42 AM
    Cold start problems M104 engine with HFM Fernandez W124 E,CE,D,TD Class 12 02-18-2008 10:31 AM
    1994 C180 tranmission no reverse?!..help! grizzly_b W202 C-Class 0 02-08-2008 01:55 AM
    1994 E320 engine missing on cold start in warmer weather notwise W124 E,CE,D,TD Class 0 04-03-2006 08:58 AM
    1994 c180 power gains? punksnut W202 C-Class 3 07-26-2005 03:10 AM
