A/C compressor doesn't kick in - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 07-20-2009, 07:18 AM Thread Starter
Date registered: Jun 2009
Vehicle: 1995 SL600, 1983 380SL, 1987 560SEL, 1974 Lotus Europa TwinCam Special
I have a 1995 SL600 that recently went thru a major illness. The ASR light went on and it took 3 months for it to be up running again. My regular mechanic couldn't find the problem and I took it to the dealer. Lots of money (20k or so) later it is running fine but the a/c which was working fine before. One of the fixes was a new wiring harness plus both throttle bodies etc. The dealer said I needed a new push button assembly and quoted his usual ridiculous price. I took it back to my regular mechanic and got a rebuilt unit from GermanStar. Didn't work. I'm convinced it is a bad connection when they replaced the wiring harness. Anyone have any ideas?
moriahsdad is offline
post #2 of 7 (permalink) Old 07-20-2009, 08:34 AM
Date registered: Apr 2009
Vehicle: Current: 1987 560 SEC US, former factory trained MB tech 10 years, owner of 14 others.
I would take it back to your dealer. $20k and no air is no deal.
renaissance_warrior is offline
post #3 of 7 (permalink) Old 07-20-2009, 11:17 AM
Musikmann's Avatar
Quoted: 6 Post(s)
+1 for the dealer. They should have a 12 month warranty on parts and labor. But don't mention taking it to your Indy because then they might try and blame him.
Musikmann is offline
post #4 of 7 (permalink) Old 07-20-2009, 01:24 PM Thread Starter
at this point I wouldn't trust the dealer to change the license plate
post #5 of 7 (permalink) Old 07-20-2009, 05:42 PM
RKH
RKH's Avatar
Date registered: Apr 2008
Vehicle: Departed 1998 SL500 (and the Pano is in Bogota)
Quoted: 495 Post(s)
$20K You can pick up a SL600 in good working order for less that that now a days.
One thing to check : if the charge level (pressure) is too low, the A/C clutch will not engage (so that it wouldn't burn out the compressor).
RKH is offline
post #6 of 7 (permalink) Old 07-20-2009, 09:01 PM
Musikmann's Avatar
Quoted: 6 Post(s)
LOl, your call but the place that did the service should be held responsible.
post #7 of 7 (permalink) Old 07-21-2009, 02:05 AM
Chris A's Avatar
Date registered: Jun 2006
Vehicle: 2001 SLK 320
Point out the expense you have already put out. this should be no charge..
Women can fake orgasms. . . . men can fake whole relationships.
Chris A is offline
kick down jabus38 W163 M-Class 25 11-05-2012 01:23 PM
ANyone know how to replace compressor clutch on OM617 while compressor still attached to loss W123 E,CE,D,CD,TD,TE Class 16 06-22-2010 09:26 PM
A/C compressor won't kick on, any ideas? rph74 W126 S,SE,SEC,SEL,SD,SDL Class 11 04-10-2007 05:01 PM
can i change the stock a/c compressor with a non oem compressor? eso7 W123 E,CE,D,CD,TD,TE Class 6 01-18-2005 05:19 PM
$15 5-in-1 air compressor for those that bought used SLKs with missing compressor Black98SLK230 R170 SLK-Class 2 11-29-2004 03:20 PM
