190E Hesitates/Surges Until warmed up.......Suspect Air Intake/Breather Hose - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 07-18-2009, 05:17 AM Thread Starter
Date registered: Jul 2008
Vehicle: 1989 Mercedes Benz 190E 2.6
Smile 190E Hesitates/Surges Until warmed up.......Suspect Air Intake/Breather Hose
I have a 190e with 218,000 miles that hesitates until it is warmed up. I'm suspecting it has to do with a cracked air intake/ breather hose going from valve cover to air filter, My question is I noticed what looks like a small vacuum tube coming from the side of it. It has cracked and broken off. Can anyone tell me what function this particular hose/tube serves? Thanks for your help in advance.
rdoepker is offline
post #2 of 7 (permalink) Old 07-18-2009, 09:42 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Cold engine requires a richer than usual fuel mixture to run properly.
On yours, this is accomplished via temperature sensor and computer which activate cold start injector and idle control valve.
Vacuum leaks indeed defeat the purpose--doesn't matter what function of any line is, it must be connected and not leaking. This is indeed first thing to fix. NOTHING there is something that is not needed nor something that doesn't matter.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #3 of 7 (permalink) Old 07-18-2009, 10:21 AM Thread Starter
Thanks for the response Kent. I will be replacing the cracked air intake breather hose from the valve cover to air filter. I'm having a hard time finding this rubber coated tubing that runs from the little hole on this air intake/breather hose to who knows where. I haven't had the chance to look yet. Any suggestions on where I may find this part or what it's called? I do frequent Autohausaz a bit and couldn't find it listed. Thanks again.
rdoepker is offline
post #4 of 7 (permalink) Old 07-18-2009, 11:09 AM Thread Starter
Here are the pics for my 190e 2.6 in what I'm referring to. I checked my manual and can find nothing of this piece either. Thanks
ID:	249803   Click image for larger version
Last edited by rdoepker; 07-18-2009 at 11:12 AM. Reason: Photos didn't upload properly
rdoepker is offline
post #5 of 7 (permalink) Old 07-18-2009, 08:20 PM Thread Starter
I did end up solving this mystery of mine. The vacuum line goes to the fuel pressure regulator. It provides vacuum to the fuel pressure regulator diaphragm. Now I just got to find this rubber grommet vacuum piece I heard the part is only around $5.00 - $6.00 bucks. Anyone know what this part is called or have a part #?
rdoepker is offline
post #6 of 7 (permalink) Old 07-20-2009, 12:04 AM
Date registered: Dec 2008
Vehicle: 1993 190E 2.6, 1990 300SEL, 1992 300SE, 1992 400E, 1987 190E 2.6 murdered by my brother.
It doesnt matter. Mine was broken and I drove it for many months with zero problems. My MB mechanic even told me to not worry about it. Its for the engine to breath. No big deal. He was right.
There is one rule...there are no rules!
Runninrebel211 is offline
post #7 of 7 (permalink) Old 07-20-2009, 06:54 PM Thread Starter
Well that's good to know. I did end up finding the vacuum connector I needed from autohausaz. Part # 1298050444
rdoepker is offline
COLD AIR INTAKE OR BREATHER HOSE ezrunner W203 C-Class 1 03-15-2009 09:25 PM
air/breather hose intake parts question! jdjones2001 W201 190-Class 2 05-06-2008 07:21 AM
valve cover breather hose to top of air filter verisoph W126 S,SE,SEC,SEL,SD,SDL Class 5 02-15-2008 06:59 AM
Air Intake/Breather Hose Question goofyguy W126 S,SE,SEC,SEL,SD,SDL Class 5 02-02-2008 11:16 PM
Hesitates then Surges on accel when cold CambridgeMA W210 E-Class 5 12-29-2007 09:05 AM
