C240 faulty LF signal - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-16-2009, 09:57 AM Thread Starter
Date registered: Jul 2009
Vehicle: 2000 S430, 20" staggered wheels
I've tried everything, changed the light bulb, check the fuse, check the flasher and still no resuts, please help.......... also, do I have to go the dealer for a electronic keyfob replacement or there's a way to reprogram another key without paying the $250.00 at the stealership. The reason I ask is, I've a additional key from another car and would like to program it to use in my car(2002 C-240 (W203). Thanks for any all the help you guys could give me...
lighting is offline
post #2 of 3 (permalink) Old 07-16-2009, 11:39 AM
Musikmann's Avatar
Quoted: 6 Post(s)
I can't help with your turn signal but is it only the left front one not working?
You absolutely cannot have some other key programmed to your car. It must come from an authorized MB dealer who orders them directly from MBUSA. The new key will already be programmed to your car when the dealer receives it.
Musikmann is offline
post #3 of 3 (permalink) Old 07-17-2009, 09:49 PM
Date registered: Apr 2009
Vehicle: 1999 E300TD
the turn signal problem is the connection in the connector, there are a set of wiring updates that add a seperate ground for the signal bulb. they are pretty cheap and someone with general knowledge should be able to install them..le me know if you need the part number for the wiring updates
saleen1276 is offline
2005 C240 - Weak reception of key signal gmoore4464 W203 C-Class 20 09-19-2015 09:05 AM
How to change a Turn Signal Lever in a 2004 C240 4Matic Stocks3019 W203 C-Class 3 05-10-2009 10:13 AM
Signal lights in mirror cause faulty lamp message? axncatsma C208/A208 CLK-Class 8 07-21-2008 09:21 AM
Cracked Mirror Signal Lens - Faulty Design? BAZMAN R171 SLK-Class 6 10-18-2005 02:03 AM
C240 classic vs. C240 Elegance hArpOoN W203 C-Class 7 06-06-2004 11:46 PM
