2001 W210 locks won't work - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 07-15-2009, 02:20 PM Thread Starter
Date registered: May 2008
Vehicle: 2001 E320 Wagon
Just today the locks on my E320 Wagon quit working. Regardless of which fob I use or the inside button, the locks won't engage....no sound...nothing. The only thing I get is the side marker flash when I hit the lock button.
Ideas?
I know these locks are vacuum. But that's about all I know. If it helps all the doors are currently unlocked, but my wife said when she was at the store, the tailgate would not unlock.
gcavy1 is offline
post #2 of 10 (permalink) Old 07-15-2009, 02:57 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Correct, the locks are a vacuum function of the PSE or pneumatic system equipment. Check the pump and associated fuse and relay. It also might be a vacuum hose connection somewhere. Good luck.
Musikmann is offline
post #3 of 10 (permalink) Old 07-15-2009, 03:49 PM Thread Starter
thanks. do you know which box has the fuse/relay?
gcavy1 is offline
post #4 of 10 (permalink) Old 07-15-2009, 03:57 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Sorry, no I don't and unfortunately a lot of members have reported their cars lack various fuse charts. BTW, you have a W210 and we have a forum devoted to these. Try posting there too (scroll down from here and look in the Sedans section). There are several quite knowledgeable members there, not me, who will have a better idea about fuse and relay locations.
post #5 of 10 (permalink) Old 07-16-2009, 08:23 AM Thread Starter
I've posted there before and will do...just thought the general forums might be better since I think this is a common MB problem
gcavy1 is offline
post #6 of 10 (permalink) Old 07-16-2009, 11:32 AM
Musikmann's Avatar
Quoted: 6 Post(s)
OK. As far as I know this is a common problem with MBs but another reason I mentioned posting there is we have at least 2 wagon owners, both of whom are very good with troubleshooting.
post #7 of 10 (permalink) Old 07-24-2009, 04:06 AM
Date registered: Jul 2009
Vehicle: SL500 2005 Purchased 2014 (It's a Classic)
reset locks
Ideas?
I had this problem with my S500 2001/2 it started with the battery going flat I recharged the battery but it still would not lock. I went to fill-up with gas and the filler cap was locked I went to the boot but was unable to unlock, until I entered the key this opened the boot and reset all the door locks and opened the filler cap... it now is back to normal just got issues with the battery?
itresolve is offline
post #8 of 10 (permalink) Old 07-25-2009, 02:17 PM
Vehicle: 2001 E320 4Matic
I am currently having the same problem with my 2001 e320 sedan. Some of the central locking fuses are in the fuse box under the rear seat and some of the fuses are in the fuse box under the hood. Let me know if you need a copy of the fuse cards and I can perhaps post a photo.
silvermoon1959 is offline
post #9 of 10 (permalink) Old 07-31-2009, 04:52 PM Thread Starter
Seems my fuses are all fine. Can someone get me a quick run down of the vacuum system? Are there simple ways to check it? How does the canister under the seat function? Does it draw vacuum off of the engine?
thanks!
gcavy1 is offline
post #10 of 10 (permalink) Old 07-31-2009, 08:38 PM
Chris A's Avatar
Date registered: Jun 2006
Vehicle: 2001 SLK 320
gcavy1, I totaly do not know your car at all but MB loves to stick a PSE unit in the trunk that provides vacume to the door locks.
Women can fake orgasms. . . . men can fake whole relationships.
Chris A is offline
    G500 Locks don't work!!! Anyone have this issue? G-wagen_enthusiast G-Class 6 11-24-2008 12:33 AM
    door locks wont work at all tallerthanu420 General Mercedes-Benz 0 08-07-2008 08:00 PM
    door locks wont work right benz420 W126 S,SE,SEC,SEL,SD,SDL Class 3 01-12-2006 12:47 PM
    Door locks suddly do not work IceBlue_1980_300TD W126 S,SE,SEC,SEL,SD,SDL Class 3 12-30-2005 10:13 AM
    Power Locks don't work anymore Guest (MBNZ) W124 E,CE,D,TD Class 6 02-16-2002 06:57 AM
