W124 E280 1993 brakes problem - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 07-15-2009, 01:20 AM Thread Starter
Date registered: Mar 2009
Vehicle: Mercedes E280 W124 1993
Send a message via Skype™ to dlznet
Question W124 E280 1993 brakes problem
Hi!
I'm a new member, and since joining I've had a strange problem with the braking system of my W124 E280 1993. It all started after I had a new air con evaporator fitted, which is a big job, involving removing the dashboard and also removing the vacuum servo unit and master cylinder.
When the job was complete, the brakes behaved as follows:
The pedal had very little effect until at about two-thirds of it travel the brakes locked on suddenly. I took the car back to the workshop.
After a number of tests and checks a new servo unit and cylinder was sourced and fitted. Now it's slightly better in that the brake pedal does start to have an effect at the beginning of pedal travel, but then there comes a point where the brakes suddenly go on very hard, rather than progressively. When travelling slowly this means a sudden stop, but I'm a bit scared to see what happens at speeds over 30 mph if I forget to treat the brake pedal very delicately.
Help!
Thanks!
dlznet is offline
post #2 of 2 (permalink) Old 07-15-2009, 04:08 AM Thread Starter
Thank you, livefreeordie. It looks good to me!
dlznet is offline
    To buy, not to buy? W124 1993 E280 wagon reddevil2 W124 E,CE,D,TD Class 3 03-13-2009 07:58 AM
    W124 E280 Interior Cheeky_Munkey W124 E,CE,D,TD Class 1 02-22-2009 10:12 AM
    Considering an 1993 E280, would appreciate assistance StianS W124 E,CE,D,TD Class 3 11-26-2008 08:45 AM
    W124 E280 Simenye W124 E,CE,D,TD Class 2 07-28-2008 09:51 PM
    CD player - 1993 e280 jfunk Audio & Telematics Forum 3 08-17-2005 04:43 AM
