2001 C320 Ignition Coil Issues-Need Help Bad - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 07-14-2009, 07:07 PM Thread Starter
Date registered: Jul 2009
I bought the OBDII code reader and found the code PS303-misfire cylinder 3. I replaced the plugs and wires and still same problem. I bought a spark tester and that is the only ignition coil not putting out a spark at all. I replaced the ignition coil 30 minutes ago and start the car up, same issue. I test the coil for spark and nothing. I am stumped because if I have new plugs, wires, and ignition coil, what else could it be? Car runs a little rough at low speeds, and when a/c is on it sometimes cuts the car off and runs rougher. Please help
rmariscal is offline
    DIY Ignition Coil Repair on 2001 C320 krislong W203 C-Class 2 12-19-2008 09:19 AM
    c320 ignition coil 01C320 W203 C-Class 4 12-17-2008 01:45 PM
    C320 Issues (Good and Bad) wsrichrich W203 C-Class 2 04-03-2008 12:07 PM
    99 ML430: How to diagnose a bad ignition Coil. Bob_ml430 W163 M-Class 3 10-07-2005 02:46 PM
    Had cylinder #2 ignition coil bad. $600 to replace it. I really wonder about dealer labor AC_ML W163 M-Class 7 11-11-2003 07:20 PM
