the fog lights stay on after i shut off my slk230 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-14-2009, 06:18 PM Thread Starter
Date registered: Jul 2009
it is a 1999 with real low miles, but i had to disconnect the battery the other day when they wouldn't turn off. the switch was definitely turned off. after disconnecting the battery for a while, they stayed off after i re-connected. any ideas anyone?
thnks a lot- rob in NY
robpearl is offline
post #2 of 3 (permalink) Old 07-15-2009, 04:36 AM
Date registered: Apr 2009
Mine 2001 will leave the driving lights on (if I had the headlights on) for about 20 seconds. I assume that yours did this as well only now they aren't going out after 20 seconds.
My first suggestion would be the switch may be malfunctioning. Perhaps a search may find more solutions to identify the problem with more certainty, and then pick up a used one as a replacement. I have used SoCal Mercedes Parts with success, no affiliation.
Niteshade is offline
post #3 of 3 (permalink) Old 07-15-2009, 11:44 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
This could be the system to provide you temporary light so you can get your key in the door of your house. Check owners manual to see if your car has this.
Otherwise, you have a "stuck relay" or other failure in some box of electronics.
Kent Christensen
'07 GL320CDI
lkchris is offline
    98' SLK230 - Driver side door needs more strength to shut jara1 R170 SLK-Class 9 04-25-2009 06:02 AM
    Aux, Front Fog, Rear Fog Lights Wiring MKappeli G-Class 3 10-20-2008 04:07 PM
    1998 slk230 fog lights edkalerman R170 SLK-Class 4 07-22-2006 02:23 PM
    ML55 fog lights & ML Sport Package fog lights angldrkns9 W163 M-Class 0 10-27-2003 06:12 AM
    Intergrated fog lights and fog lights questions Balu W163 M-Class 8 10-18-2001 07:27 AM
