Need advise - tire size CLK wheel - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-11-2009, 06:47 PM Thread Starter
Date registered: Apr 2009
Vehicle: 1996 C280 and 2010 E350 4-Matic
Quoted: 8 Post(s)
Question Need advise - tire size CLK wheel
I have staggered wheels on my CLK - 16" wheels with 7" wide in front and 8" wide at rear. Running 205/55/16 at the front and 225/50/16 at the rear - just as factory recommends.
The question is for the spare. I bought an 8" wide wheel for the spare to replace the 7" wide steel one. It is identical to the two rear wheels. Do you think I can mount a 215/55/16 on this rim? My thought is that if I had to put the spare on the front for an extended period, 215 would be preferable to 225..
Advise, please.
Walterk55 is offline
post #2 of 3 (permalink) Old 07-11-2009, 10:20 PM
Diesel Benz's Avatar
Quoted: 32 Post(s)
For extended periods the 215/55/16 tyre is not good because it has a different diameter from your other wheels. You would likely get ESP and other errors.
You could explain if you are changing the current spare for aesthetic reasons or something else, to motivate forum members to respond. I would keep the current spare instead of the new wheel with a 215/55/16 tyre if the current one is in good condition.
Diesel Benz is offline
post #3 of 3 (permalink) Old 07-12-2009, 08:46 AM Thread Starter
Quoted: 8 Post(s)
Thanks for the reply - current spare is worse
The current spare is a 16" steel wheel - 7" wide - with a 205/50/16 tire on it. The diameter is way off the other 4 wheels.
My thought was to get a spare alloy rim like the others in style so that if anything happened to one of the wheels, the spare would be able to take the place of the damaged wheel. BUT, of course, I had to choose between a 7" wide and an 8" wide (difficult to have both in the trunk !!)
Sounds like I need to have the same diameter as the other 4 wheels - and in that case, I should go with the 225/50/16 tire on the 8" wide rim.
Thanks for pointing out that I could have ESP problems.
Any other members are welcome to join in - I want to do the "right" thing....
    Replica Wheel AMG Sport Wheel Tire size question nunonbreak The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 01-26-2010 07:31 PM
    Wheel and tire size Turbinetom W126 S,SE,SEC,SEL,SD,SDL Class 11 11-01-2008 07:45 PM
    clk amg tire size wolffbenz W202 C-Class 4 10-24-2008 04:54 PM
    tire wheel size vdubpower W140 S-Class 2 02-22-2007 11:11 AM
    2001 S430 on 20 inch? what prefered tire size - please advise!! Mirzas430 General Mercedes-Benz 0 03-26-2006 04:08 PM
