Check Engine Light coming on and off - Page 2 - Mercedes-Benz Forum
post #11 of 21 (permalink) Old 07-09-2009, 02:13 PM
stox's Avatar
Date registered: Dec 2004
Vehicle: 1996 C36, 1995 S500 Coupe, 1985 190E 2.3
Send a message via Yahoo to stox
Originally Posted by ADRiANADRiAN View Post
i got a 95 e320 and all of a sudden the check engine light came on! any ideas??
Your mechanic is lonely.
Get the code read and find out.
stox is offline
post #12 of 21 (permalink) Old 07-11-2009, 06:58 PM
wpterry's Avatar
Date registered: Jan 2007
Vehicle: 1984 380SL, 2000 BMW Z3
Quick Check - Disconnect the Battery
My '89 420SEL's came on on a trip (on my way home). Took it to my mechanic and he was busy for a couple of days. He told me to disconnect the battery for about 10 minutes to reset the computer. Did that and it's not come on since on several long trips.
No biggie, just had to redo the radio presets and it was a cheap fix.
wpterry is offline
post #13 of 21 (permalink) Old 07-11-2009, 07:29 PM
ohlord's Avatar
Vehicle: 1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
Quoted: 5 Post(s)
Clearing the code by
disconnecting the battery will not clear the problem.The code is still actively stored in the ecu and the problem still exists.
Not seeing the light may comfort you but in the long term if it is a critical issue your bliss turned to ignorance by the advice of a shitty mechanic might cost you far more than you bargained.
Op cam sensor easy diy front of engine,on head. examine for oil leak common to the issue.
95 E320 check gas cap flip over gasket and check all vac lines to engine.
95's were also subject to the dreaded wire harness issue so examine your wires. If they look like mummy wraps better start saving the moola
anyone else want to throw something into this convoluted catch all post
00-02 drivers side self dimming heated mirror
17mm special spark boot tool
O2 plug and play sensors
16mm spring loaded swivel spark socket
trans dipstick and magnet
Mercedes Benz Lyrics
Artist(Band):Janis Joplin
"Oh Lord, won't you buy me
a Mercedes Benz"
ohlord
"Follow Peace,center Life"
ohlord is offline
post #14 of 21 (permalink) Old 07-11-2009, 08:20 PM
Date registered: Jun 2009
I have a 98 Kawasaki KX250 that fouled the plug. Any ideas?
Pembroke36 is offline
post #15 of 21 (permalink) Old 07-11-2009, 08:32 PM
Date registered: Dec 2008
Vehicle: w204 (C350ELE)
Of course, trade it in for a Harley.
JoeVal is offline
post #16 of 21 (permalink) Old 07-12-2009, 06:27 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 86 Post(s)
Originally Posted by wpterry View Post
it was a cheap fix.
Not a fix. At least OBDII is easier to read than the OBDI/OBD.
Mike
Michael Pillay is offline
post #17 of 21 (permalink) Old 07-12-2009, 06:59 AM Thread Starter
Date registered: Apr 2008
They had to keep it in over the weekend. I'll get the report tomorrow when the wife get's it back. It was bad news. Leaking oil all over the engine. Cost 1800 plus taxes.
I think Skodas have a better reputation that MB's now......
joedeane is offline
post #18 of 21 (permalink) Old 07-12-2009, 07:55 AM
Musikmann's Avatar
Quoted: 6 Post(s)
Sorry to hear that Joe. A 2003 w/58,000 should not be having anything that serious going on (my turn to state the obvious). Have you had to add any oil to it recently? If oil is literally "all over the engine" it looks like you would have gotten an add oil light. BTW, did you ever ask on the W203 forum in case this is a common occurance?
Skodas? Good one!
Musikmann is offline
post #19 of 21 (permalink) Old 07-16-2009, 05:05 PM
wpterry's Avatar
OK - Battery Disconnect Did Not Fix Problem
So my shitty Mercedes mechanic of over 25 years told me wrong. I've driven over 5000 miles since the shitty mechanic told me wrong and have had no re-occurance of the check engine light coming on. Hmmmmmm
I bow to the greater knowledge of Ohlord
wpterry is offline
post #20 of 21 (permalink) Old 07-16-2009, 06:58 PM
Musikmann's Avatar
Quoted: 6 Post(s)
So my shitty Mercedes mechanic of over 25 years told me wrong. I've driven over 5000 miles since the shitty mechanic told me wrong and have had no re-occurance of the check engine light coming on. Hmmmmmm I bow to the greater knowledge of Ohlord
1989 cars might be a bit before ohlord started working on them. In his defense, he's usually correct if the problems concern slightly newer models. Does your car even have an ECU that stores error codes? At least on more modern models, once a code is stored by the ECU it stays there until the problem is fixed and the code is cleared afterward.
    How to check code for check engine light 94 E320 W124 Synd W124 E,CE,D,TD Class 1 05-24-2007 02:37 PM
    Check Engine light keeps coming on Chard W140 S-Class 0 08-14-2004 02:25 PM
    Check coolant light coming on maneesh W163 M-Class 8 01-31-2004 01:33 PM
    Check Engine Light keeps coming on. BAverett W140 S-Class 4 02-10-2003 05:21 AM
    my check engine light has been coming on lately.... bib C208/A208 CLK-Class 4 06-26-2002 08:41 AM
