question on blend air actuator - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 06-30-2009, 09:59 AM Thread Starter
Date registered: Jun 2009
Vehicle: 2003 ml 320
does the blend air actuator control the heat and A/C into the car or is it just for the A/C.
michael katz is offline
post #2 of 5 (permalink) Old 06-30-2009, 09:24 PM
PMV
Vehicle: 1999 ML320
I believe that the actuator motor opens the flap thus allowing the mixing of warm/hot air into the cabin.
A closed flap would stop the flow of this hot air into the cabin.
At least this is what I have observed when I removed the radio an manually pushed the actuator flap linkage. Effectively blocking the hot air from entering the cabin.
My actuator motor (plastic gears!) is not working properly. This sounds like a common issue with the ML. It is hot in Texas and having some cold air is nice.
I'm going to wait until the fall to replace this motor.
PMV is offline
post #3 of 5 (permalink) Old 06-30-2009, 09:40 PM
What model is it and what is the problem?
Pembroke36 is offline
post #4 of 5 (permalink) Old 07-01-2009, 04:55 AM Thread Starter
It is a 2003 ML320, No heat or A/C in cabin, the three dials light up, air control blows control change speeds, changes locations in cabin, no other problems, defroster switch works
post #5 of 5 (permalink) Old 07-14-2009, 07:12 PM
Tin
Date registered: Jul 2009
I have a 2000 ML320 with same problem. Well, I only get extreme heat. AC kicks on and the AC pipes are freezing cold. Im suspecting the control box (Denso Box #tn277300-0790) behind the HVAC unit. Can that also be the cause? I would hate to remove the dash for the actuator and find out its the box behind the HVAC.
Tin is offline
    DIY VIDEO Air blend motor DETANE W163 M-Class 39 05-27-2011 08:04 AM
    Blend air flap scoutmstr R170 SLK-Class 0 05-20-2009 12:36 PM
    Blend Air Actuator Fix gglyptis W163 M-Class 7 08-20-2008 10:45 PM
    Blend air flap actuator motor problem ron in sc W163 M-Class 14 01-25-2007 11:09 AM
    E220CDI Air Mass/Air Flap actuator/heater fault SadGraham General Mercedes-Benz 0 07-03-2005 06:10 AM
