ISSUES WITH MY CLK320 Transmission - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 06-28-2009, 07:45 PM Thread Starter
Drkanglgabriel's Avatar
Date registered: Dec 2007
Vehicle: 2007 E550 Black / Black
Angry ISSUES WITH MY CLK320 Transmission
I am having several issues with my 04 clk320.
1. Sometimes the car doesnt start when i put the key in and turn it. IT will eventually start 4 to 5 seconds later if you hold the key in the start position. Seems like an electronic issue and it only happens every so often. this ever happened to anyone else?
2. every fourth or fifth time i start the car, the gears seem to get locked in first. It just bounces off the rev limiter and wont up shift, then it jerks to a stop when you slow down. Typically leaving it overnight and starting it the next day the problem goes away.
3. when the car is behaving normally, sometimes when i slow down to make a turn or something, and then press the accelorator, it takes a second like its thinking, and then goes. This could be related to problem two i suppose, but again, any ideas, would be helpful.
Again not all the time just occasionally for all three issues.
There are presently no active error codes on the car at all. Thanks for the help!
Drkanglgabriel is offline
    Problems with CLK320 Transmission?? szabelin C209/A209 CLK-Class 31 02-10-2014 08:22 AM
    Transmission issues (1990 300E, 3.0L, 722.5 transmission) Eric@StarSuzuki W124 E,CE,D,TD Class 5 04-13-2011 07:29 PM
    CLK320 starting issues firstbenzclk320 C208/A208 CLK-Class 0 11-15-2008 01:03 PM
    1999 clk320 needs transmission goldmember For Sale/Wanted/Trade/Giveaway 0 11-01-2007 09:58 PM
    TRANSMISSION IN CLK320 cgmike10 C208/A208 CLK-Class 0 10-23-2002 05:51 PM
