Cold start problem - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-28-2009, 05:04 PM Thread Starter
Date registered: Jun 2009
Cold start problem
Have a C180 salon, manual, petrol, 1993 model., 110K miles.
Just had car service ( new plugs, filters,oil...), ball joints changex2; 4 new tyres, MOT passed;
however when starting the car in the morinings it would just turn and fire and ll Ok.
Now it turns but does not fire, have to press the accelerator pedal for it to fire and then it spluters and misfires, finally warms up for me to move in first gear but with very little to no power.
After about 3 mins the car warms up and all is OK - power back, no misfiring or splutering; however not as smoth as before but driveable.
Have checket the temp gauage sensro read 5K ohms cold and 20Ohms when hot.
Any ideas...manual states could be throttle body? any tips.
Hope you guys ( & gals) can help.
Ta
C180MB is offline
post #2 of 4 (permalink) Old 06-29-2009, 07:16 PM
Date registered: Apr 2009
Vehicle: Current: 1987 560 SEC US, former factory trained MB tech 10 years, owner of 14 others.
Definitely a temp-related sensor, but I am not familiar with all of them on your model. A trottle body is not temperature sensitive, unless the air-mass sensor meters fuel by air intake temp as well, if so equipped.
renaissance_warrior is offline
post #3 of 4 (permalink) Old 06-30-2009, 02:30 AM Thread Starter
Question Temprature sensor OK
The temp sensor is OK as it reads 5K ohns when cold and 20 ohms when hot.
Trouble shooting section of Haynes Manual seems to imply vacumm leak, any idea what that could mean?
thx
C180MB is offline
post #4 of 4 (permalink) Old 08-25-2009, 12:39 AM Thread Starter
It was the air-flow mass meter - seems to have cured the cold start problem. THE AFM was passing the wrong reading to the ICU which was doing all sorts of things to accomodate the incorrect reading - all fine so far.
C180MB is offline
    cold start problem bulahee W201 190-Class 0 07-30-2006 12:54 PM
    Cold Start Problem MBGary W126 S,SE,SEC,SEL,SD,SDL Class 7 10-06-2005 01:05 PM
    Cold Start Problem 230Terry W124 E,CE,D,TD Class 7 04-27-2005 02:07 PM
    cold start problem needs 2 tries dstorfer W210 E-Class 2 01-27-2004 07:39 AM
    Update on my cold start studdering problem - problem fixed? Douglas-Indianapolis R170 SLK-Class 4 04-25-2001 05:28 AM
