SL320 oil mixing with coolant - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-27-2009, 04:47 PM Thread Starter
Date registered: Jun 2009
Question SL320 oil mixing with coolant
hi all i have a SL320 on a 1994 year i have had oil mixing with coolant, i done the head gasket and flushed the cooling system out 7 times but it cream has come back and also still losing oil. is this common for these and what causes this ie head, block, oil cooler would be very greatfull on some help as i no its going to cost alot of money whatever the problem #
many thanks lee
leeboy is offline
post #2 of 3 (permalink) Old 06-27-2009, 05:20 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
Was the head and/or the block warped?
flyboyike is offline
post #3 of 3 (permalink) Old 06-27-2009, 06:14 PM
Sounds like a head gasket. Most 104 engines had head gasket replacements done while the cars were still under warranty. Common problem.
Pembroke36 is offline
    96 sl320 leaking coolant Randy Neefs R129 SL-Class 4 05-04-2009 06:56 AM
    SL320 Oil change firstsl General Mercedes-Benz 1 11-22-2008 03:09 PM
    Oil Level - 95 SL320 sl320man R129 SL-Class 3 09-12-2006 06:33 PM
    Oil Gurus - what are the repercussions of mixing Oil Weights?? jangr320 W163 M-Class 1 03-04-2005 10:09 AM
    1997 SL320 - what engine oil to use??? Guest (MBNZ) R129 SL-Class 1 06-16-2002 11:06 PM
