300ce Transmission Upgrade - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-26-2009, 12:36 PM Thread Starter
Date registered: Jun 2009
Does anyone know of a transmission upgrade for a 1991 300CE Coupe which would require little or no fabrication. My 300ce requires 3100rpm to achieve 70mph so I assume it has no overdrive. Is this normal? Would a newer transmission upgrade be possible which would improve my fuel efficiency?
Thanks,
Tcheairs
Tcheairs is offline
post #2 of 2 (permalink) Old 06-27-2009, 08:18 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
This is normal for W124.
Mercedes FINALLY went to lower highway gearing with the 5-speed auto in the W210.
You should get a W210 or W208 or W209 because you can't put the 5-speed in your car for less than it would cost you to trade cars.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
    300ce brake upgrade to r129? zebinheimer300e W124 E,CE,D,TD Class 10 10-28-2008 09:50 AM
    91 300CE 24 Transmission question gorfllub W124 E,CE,D,TD Class 6 01-24-2008 10:24 AM
    300CE sportline - upgrade from a W201 StarGazer W124 E,CE,D,TD Class 16 01-30-2007 12:07 PM
    upgrade to W124- 300ce StarGazer W201 190-Class 4 01-15-2007 06:27 AM
    300ce w124 alloy wheel upgrade question DIMITRIAR The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 12-17-2003 07:30 AM
