Air Con - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 06-26-2009, 03:39 AM Thread Starter
Date registered: Apr 2008
Air Con
Trailing round forums to see if any help
Has anyone any tips on removing the dashboard on my 1992 500SEL
Evaporator behind dash leaking.My fault as called to phone and left bottle connected which fell over filling system with a litre of R134a Opps!
Does wheel and airbag have to come off. ? Thanks.
philg101 is offline
post #2 of 5 (permalink) Old 06-26-2009, 04:43 AM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T current 2014 lexus LS460
To change the evap, the entire dash comes out including console, it is not for the inexperienced. There are lots of wires, hoses and things. It is usually a $4000 job at a dealer. The link discusses it on a coupe
K6JRF Auto Page
Peter Guenther is offline
post #3 of 5 (permalink) Old 06-26-2009, 09:25 AM
stox's Avatar
Date registered: Dec 2004
Vehicle: 1996 C36, 1995 S500 Coupe, 1985 190E 2.3
Send a message via Yahoo to stox
This question might be better phrased, "How do I remove the car from the evaporator?" Legend has it that the first piece they put on the assembly line was the evaporator, and they then proceed to build the car around it.
stox is offline
post #4 of 5 (permalink) Old 06-26-2009, 01:42 PM
Date registered: Feb 2008
Vehicle: 2004 W220 (S430) ; 2001 R129 (SL500) Sport
Location: Alabama Gulf Coast--formerly Charlottesville, VA
My W124 was the same way. Replacing the evaporator basically required the removal of everything in the interior forward of the B pillar except the seats. If I recall, the flat rate (remember this is a simpler 124) was 20 hours or some such.
The advice you are receiving is accurate; this is not a job for an amateur--even a talented one with time on his/her hands. You may find it more expensive to repair than the car is worth. I found an indie shop to replace mine, which turned out to be less than half what the dealership quoted, but it was still $2k or something like that including the new part.
Good luck.
"Don't pick a fight with an old man. If he is too old to fight, he'll just kill you."--John Steinbeck
DrJfrmLA is offline
post #5 of 5 (permalink) Old 06-26-2009, 05:03 PM
Date registered: Mar 2009
Vehicle: 2006 E350
I had the dash out of my W124 a few years ago. airbags, steering wheel, instrument cluster, everything had to come out. I needed to pull the dash to replace the vacuum pods, but the evaporator was right there and could have easily been pulled as well.
Though it was a lot of work, as long as you proceed carefully with the appropriate service manual pages at hand, it shouldn't be too bad. I started about 6am and was done about 3pm.
Regarding the airbags: they are really safe. The procedure in the service manual covered that nicely. I did need a special tool to remove the airbag from the steering wheel.
My advice would be to proceed slowly and carefully, and do the job when you are not rushed and have no deadlines ( and can do without the car for a week if necessary).
Dave Barnhart
Phoenix, AZ
2006 E350
Past Mercedes:
1993 300E
1984 300D
My E350 Blog
My 300E Website
dbarnhart is offline
    Air con ianrandom W126 S,SE,SEC,SEL,SD,SDL Class 11 06-17-2009 07:48 PM
    Air con dekay V-Class 0 04-21-2007 03:20 PM
    Air Con ? digio W163 M-Class 7 10-15-2005 01:53 PM
    Air Con pcorrick R170 SLK-Class 13 09-13-2004 09:55 AM
    air con AmoS500 W140 S-Class 2 07-21-2003 09:19 AM
