Alarm won't stop - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-25-2009, 07:04 AM Thread Starter
Date registered: Mar 2008
Alarm won't stop
Hello,
I've got a 1993 600 SEL with a dead battery. New battery was put in but alarm immediately goes off and won't stop. The alarm seems to be preventing the engine from starting. I have to disconnect battery for the alarm to stop.
Can I somehow disconnect the alarm so that the battery has time to start the engine?
Thanx,
Sojourner47 is offline
post #2 of 2 (permalink) Old 06-25-2009, 08:40 AM
Date registered: Jun 2009
Vehicle: none
Sounds like you might be dealing with an after market alarm system. If so look for a push button or mini toggle "valet" switch to disarm the system with the ignition turned on. If it is after market and that doesn't work, you will need to find the alarm brain and unplug it. If the starter kill is normally closed you should be able to start the vehicle, otherwise you will need to reconnect the starter wire. I am assuming that you do not have a remote. You can also try locking and unlocking the drivers door with the key.
WestCoastWes is offline
    Alarm Won't Stop!!! HELP!!! RichSLK323 R170 SLK-Class 10 02-27-2008 02:45 PM
    HELP! Alarm won't stop going off! VeeZyzzx W201 190-Class 13 01-31-2008 09:39 PM
    My Alarm wont stop! g2blkemike W126 S,SE,SEC,SEL,SD,SDL Class 1 03-27-2006 08:56 AM
    Sprinter stop/stop system Fulcrum525 W901-905 Sprinter 0 02-19-2006 02:52 PM
    Pressing STOP lever does not stop engine, Help! IceBlue_1980_300TD W123 E,CE,D,CD,TD,TE Class 5 08-12-2004 04:41 PM
