W126 Blower motor - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-25-2009, 04:18 AM Thread Starter
Date registered: Mar 2009
Vehicle: 420SEL, 300SEL
W126 Blower motor
Blower works fine on all speeds until engine is running then it stops
In other words when key goes from Pos 2 to Pos 3 it cuts out supply to the motor
Is the motor controlled by a relay?
I dont have wiring diagram
Thanks
mw
weathersone is offline
post #2 of 3 (permalink) Old 07-07-2009, 09:03 PM
Date registered: Jan 2007
First make sure you are actualy loosing power. I had one a while back that would do that, when I checked the motor I found there was a loose connection at the fan. I could move the wire and it would run then a while. I re soldered the wire to the fan and it works like a champ.
Benzronnie1959 is offline
post #3 of 3 (permalink) Old 07-10-2009, 01:40 PM
awg
Date registered: Apr 2006
Vehicle: 2001 S500,1973 Detamaso Patrera
Send a message via MSN to awg
Also check the ignition switch,they are notorious for doing this.Wiggle the key while the veh is running and see if the blower motor cuts on and off.If it does make sure you replace the electrical portion and the key portion.If you replace only the elec then I gaurantee the ignition will lock up and then you have to drill it out(and that is no fun)
awg is offline
    1998 W210 E300DT Bad Blower Regulator or Blower Motor?? How to tell DieselNuts W210 E-Class 12 08-16-2012 09:32 AM
    Think I need a new Blower Motor? Miked37945 W124 E,CE,D,TD Class 7 04-05-2009 12:51 PM
    Blower motor Mouramen W201 190-Class 2 02-03-2007 04:03 AM
    A/C Blower motor radunegru W124 E,CE,D,TD Class 0 03-03-2005 08:24 AM
    Wiper Motor or Blower Motor / Resistor Pack Failure?? jangr320 W163 M-Class 3 11-13-2004 11:20 AM
