99 ml430 ignition key won't turn!!!! need phone number too!!! - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 06-19-2009, 03:02 PM Thread Starter
cadillaclady30's Avatar
Date registered: Jun 2009
Vehicle: 1999 Mercedes-Benz ML430
went to start the car and the darn key won't trun. yes the battery is working, key opens door, remote opens door, yes turned stering wheel, sprayed wd40 and still nothing. called mercedes to find out how much it will cost for replacement - $170 : not even sure if that will do the trick. afraid it might be the cylindar because the key didn't want to come out nicely. does any1 have have any ideas? Also does anyone have the number to call directly to mercedes to find out how much it really cost for a replacement and to see how many keys were made????????????
cadillaclady30 is offline
post #2 of 7 (permalink) Old 06-19-2009, 04:51 PM
Kajtek1's Avatar
Quoted: 1166 Post(s)
You might be the first one that is having the problem on ML, but I had that unpleasant experience on older E class that still had blade key.
Spray lot of WD40 inside the tumbler and keep inserting and removing the key several times wiping it off between. It helped me for almost a year.
Replacing the ignition tumbler might be an easy part, but you will have different key blade for the doors.
$170 sound really cheap even if the tumbler cost less than $100.
MB has very tricky steering wheel blockade and any tampering ends in permanent lock, that require cutting and getting new blockade mechanism. You can read more about mine and other experience in W210 section.
Good luck.
Kajtek1 is online now
post #3 of 7 (permalink) Old 06-19-2009, 05:28 PM Thread Starter
just got off the phone w/dealer in Sacramento Ca. i'm in ga right now and all the dealers are closed on this side of the coast. The writer said it should cost about $250 for a new cylindar, which isn't all that bad. he also said the door cyls., and the key don't need to be changed. said ignition cyl. should be able to stay the same as the old (not sure how true that is). hoping that is all true. Right now waiting on road side to show up to see if he can get it started. in the mean time i will continue to keep trying the wd40. thanks for your response....
Cadi
post #4 of 7 (permalink) Old 06-19-2009, 05:53 PM Thread Starter
Good news? So i finally got the key to turn but now the car won't. no crank no nothing except lights on the dash. So maybe it is the battery? Still waiting on roadside only now i'm afraid to shut it/accessories off. wish me luck, roadside should be here any min.
Cadi
post #5 of 7 (permalink) Old 06-19-2009, 06:24 PM Thread Starter
ok, of course roadside gets here and it starts right up for him.... he says for me to have the tumbler and the blade key changed out. so i guess i'll be going to the shop in the morning and seeing if they can change it out.
Cadi
post #6 of 7 (permalink) Old 06-21-2009, 09:31 PM
Date registered: Jan 2009
Vehicle: 2006 ML 350
How did it end up ?
Beerman is offline
post #7 of 7 (permalink) Old 06-24-2009, 10:56 PM
Vehicle: 1999 CLK 430
Doesn't that model have an electronic key? If so it is probably the battery inside it.
DAWHIKE is offline
    ignition key will not turn Charlee General Mercedes-Benz 10 11-30-2014 05:26 AM
    Ignition Key won't turn nvest80 W210 E-Class 23 05-06-2012 07:17 AM
    '86 190e Ignition key problem- the key won't turn Guest (MBNZ) W201 190-Class 7 04-13-2010 04:35 PM
    Ignition Key Won't turn rey445588 G-Class 1 02-09-2008 09:21 AM
    Help! Key stuck in ML430 ignition mercman66 W163 M-Class 1 07-26-2006 09:24 PM
