Ways to bypass Fuel Pump Relay on 300E - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-15-2009, 05:21 AM Thread Starter
Date registered: Apr 2009
Question Ways to bypass Fuel Pump Relay on 300E
I do know this information has been posted here before but I've searched for an hour with no luck so hope you don't mind me asking here.
My 1998 300E has the imfamous non- start problem - sometimes fuel pump kicks in first try usually I have to go back an hour or more later and try again. I had similar problem on last car - 230E - and that time local garage fitted a bypass from the fuse box area to a fuse holder so when fuel pump didn't work I could insert fuse and get it running so I could start car.
We want to do same with this but he's not sure what he needs to do on this model and I am hoping someone here can help.
I know you can bypass by covering pins in the relay but doing it via fuse box or something in that area is preferable.
Please reply if you have any info on this as I miss driving my merc but need the bypass option so I won't get stuck if relay goes funny.
Thanks for reading.
shadowmike is offline
post #2 of 3 (permalink) Old 06-15-2009, 10:39 AM
Date registered: May 2009
normaly it's jumped between pin # 87 & 30 - this is for test only..
island imports is offline
post #3 of 3 (permalink) Old 06-15-2009, 09:35 PM
wbain's Avatar
Date registered: Dec 2003
Resolder the fuel pump relay connections on the foil side, especially the large pins of the relay.
wbain is offline
    w201 bypass fuel pump relay 2.0l 4cyl benzhead W201 190-Class 1 03-21-2008 01:27 AM
    fuel pump relay location and bypass info steve58 R/C107 SL/SLC Class 31 08-04-2007 03:04 PM
    power to fuel pump relay-300E rbmbz W124 E,CE,D,TD Class 6 12-03-2006 11:10 AM
    fuel pump relay (300e) killahroc W124 E,CE,D,TD Class 5 11-30-2006 05:35 PM
    300E 1986 Fuel pump relay Guest (MBNZ) W124 E,CE,D,TD Class 1 05-09-2001 06:11 PM
