1988 420SEL It Won't Start - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 06-14-2009, 03:00 PM Thread Starter
Date registered: Jun 2009
I parked my 420 SEL for a year. Went to start it today with no luck. It turns over but will not run. The Fuel pump wasn't coming on so I by passed the pump relay and got the pump to purring but it still wont fire up unless I put gas in the manifold. Its got new gas in it. HELP! Ron C
Ron C is offline
post #2 of 10 (permalink) Old 06-15-2009, 03:41 AM
Date registered: Oct 2007
Vehicle: 2002 SLK 230 1986 560SL 2008 Honda CRV
Welcome to Benzworld
livefreeordie is offline
post #3 of 10 (permalink) Old 06-15-2009, 05:53 PM Thread Starter
Thanks for the Welcome
It's quiet on this forum. If you put a question on the V Twin Forum you get a reply by the time you can press Submit!
Ron C is offline
post #4 of 10 (permalink) Old 08-02-2009, 10:46 AM
leapyfish is offline
post #5 of 10 (permalink) Old 08-03-2009, 12:29 AM
GogglesPisano764's Avatar
Date registered: Feb 2008
Vehicle: 1983 300D Turbo Diesel
Send a message via Yahoo to GogglesPisano764
Welcome to Benzworld!
Yes Honey! Thats how they sound! Its a diesel!
MBCA Member
1983 300D "Schultz" (Relocated to Canada)
1983 300D "Klaudia" (My new love)
1985 300D (Whipped then Stripped)
1985 300SD (In way over my head and let go)
2002 Suburban Z71 (Eats gas stations during trips)
2004 Aveo (Only because I enjoy stuffing my fat ass in a tiny car. Oh and it gets good gas mileage)
GogglesPisano764 is offline
post #6 of 10 (permalink) Old 10-10-2009, 08:05 PM
Date registered: Oct 2009
420 fuel pump fix
fix: 2 red wires are attached to the positive battery clamp via a special bolt. They run the s-class fuel pumps and the bolt must be spotlessly clean and tight or you will many fuel pump no start issues. always clean it ever 6 months€. If you dont have an original battery cable connector then buy one. they are 2 small red wires, alone together in wiring harness, they cause many people lots of wasted time replacing w-126 fuel pumps, filters, relays. its just those 2 wires. worst case-hook wires from rear taillights to fuel pumps to get the car home.
fontana420 is offline
post #7 of 10 (permalink) Old 10-14-2009, 04:31 PM Thread Starter
Thanks for the Info But it still will not run. I can hear the pump running but no gas in the line. What next Boss?
Ron C is offline
post #8 of 10 (permalink) Old 10-14-2009, 08:43 PM
Wink
I would disconnect both metal fuel lines from the fuel pump regulator on top on the motor on the drivers side of the bosch fuel distributor. Put them in containers to catch the gas. Then put a small amount of starter fluid in the air horn meter throat. Then crank the motor to get the engine sputtering and the low RPMs will activate the pumps, hopefully putting out some gas. It might take a while and a few trys to get gas out of the line. Re-connect, clean the air venturi and move the air horn meter valve down & up to hopefully free the internal linkage allowing gas to be injected. You could be hearing just 1 fuel pump, not 2 of them.....
post #9 of 10 (permalink) Old 10-16-2009, 06:17 AM Thread Starter
There is no fuel at the engine. One line is clear and the other seems to have an obstruction but it may have a check valve. Iv'e held my hand on each pump and they seem to be running.
Ron C is offline
post #10 of 10 (permalink) Old 10-16-2009, 07:51 AM
One line is fuel to the motor. The other is a return line. The fuel pumps have check valves. I would remove both fuel pumps off the car, place on the ground, use a car battery to check and see if they are running and if they will pump fluid (be careful if you use gas). maybe you can hook a preassure gauge to them and check resistance across the terminals. You might want to try a light oil, gas mixed with oil or "stabil" gas storage product to keep it less flamable. If the pumps do work then its your wiring harness to them or the bosch fuel distributor. I would reinstall the pumps, jumper them off a battery (not the car's wiring harness) and see if it starts. Use starter fliud to get the car up to RPM as the fuel pumps shut off after 15 seconds on some cars if the rpms are not over "idle speed".
If the car doesn't start with good pumps it could be the fuel distributor or the electrical devices hooked to the bosch fuel distributor. Also clean all sensor connections on the front of the motor near thermostat houseing. Does the COLD START valve put out gas? Disconnect it ahd put it over a container and see if its working - thats a sign of good fuel pumps. Do that first
420SEL 1988 FS, needs work hanno2s@verizon.net For Sale/Wanted/Trade/Giveaway 4 03-29-2009 02:46 PM
FS: 420SEL 1988 in Western Maryland zymurgist For Sale/Wanted/Trade/Giveaway 2 10-16-2008 04:15 AM
1988 420sel Running Rough thebenzmane55 W126 S,SE,SEC,SEL,SD,SDL Class 3 05-14-2007 08:17 AM
Hi there, 1988 420SEL, just had an accident on sunday. LondonRockz W126 S,SE,SEC,SEL,SD,SDL Class 12 10-30-2006 03:16 AM
1988 420SEL, needs a little more power MatthewJ General Mercedes-Benz 2 09-14-2004 07:29 PM
