Question about Removing Engine Sludge - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 06-13-2009, 07:42 AM Thread Starter
Date registered: Jun 2009
Vehicle: Mercedes Benz 560SEL
Exclamation Question about Removing Engine Sludge
I have sludge in my engine and went to a mechanic that was recommended for an oil change and to help clean this engine out. I bought an engine cleaner that was recommended for Mercedes. When I went to the mechanic and told him about using the engine cleaner he said he would not put it in.
He told me that yes, it will clean the top of the engine, however, the sludge will go to the bottom of the oil pan, get into the strainer and have a good chance of clogging the oil pump.
My question is, has anyone used an engine cleaner to remove sludge and what is the reality of the problem the mechanic mentiond really occuring?
Thanks for your help
Carolina560Benz
carolina560benz is offline
post #2 of 9 (permalink) Old 06-13-2009, 07:55 AM
Musikmann's Avatar
Quoted: 6 Post(s)
What engine cleaner is recommended for Mercedes?
Musikmann is offline
post #3 of 9 (permalink) Old 06-13-2009, 09:58 PM
Date registered: Dec 2008
Vehicle: 1993 190E 2.6, 1990 300SEL, 1992 300SE, 1992 400E, 1987 190E 2.6 murdered by my brother.
I used Auto-rx.com. It works very slow but quite effective at cleaning out sludge. Dont use any chemicals that will break things off in chunks as it will give your engine problems asap. Autorx dissolves the sludge and carbon build up around the ring packs and brings it over to the oil filter and traps it there. I was a not a believer at first being $26.00 for one bottle. After driving with it for 3000miles then doing an oil change. I noticed that my car wasnt as sluggish anymore. The varnish and residue on my oil cap also softened to the point where it just wiped off. Before that I tried scraping and it wouldnt even get it off as it was so hard.
There is one rule...there are no rules!
Runninrebel211 is offline
post #4 of 9 (permalink) Old 06-15-2009, 01:12 PM
Date registered: Apr 2009
Vehicle: Current: 1987 560 SEC US, former factory trained MB tech 10 years, owner of 14 others.
Risilone has always worked fine for me. Or, you could use a quart of Marvel Mystery oil, the MB tech's best friend and for air tools as well.
renaissance_warrior is offline
post #5 of 9 (permalink) Old 06-15-2009, 04:30 PM
Date registered: Jan 2003
Vehicle: 2006 CLS500 - Iridium Silver w/ AMG Sportline
Carolina560Benz
How do you know when you have engine sludge? It's something I've never had an issue w/ before.
BBZLC is offline
post #6 of 9 (permalink) Old 06-15-2009, 04:48 PM
Vehicle: w204 (C350ELE)
Post
The last time I posted about preventing sludge as a matter of long term routine, I almost was thrown off the forum. Now, here comes Carolina with the problem (e pluribus unum) and is made to feel like an UFO.
Dirt happens, not only physiologically but in every order of life. Being too lazy to drop the pan to clean the sump every once in several blue moons is neither an excuse to ignore the fact, nor to put down the victims of such problem.
After having said my thing, IMHO I would not clean the engine before taking all the garbage out. The oil piston ring will thank me for that, though the mechanic will make less money now than later when the engine has to be opened.
Chiao. JV
JoeVal is offline
post #7 of 9 (permalink) Old 06-15-2009, 09:05 PM
Chiao. JV
I guess I don't drive or keep my cars long enough, as I've never dropped a pan to clean out sludge, but I've never had a sludge problem either. Or I did and it had no symptoms, because I've never dealt had to deal with it.
BBZLC is offline
post #8 of 9 (permalink) Old 06-15-2009, 09:45 PM
Diesel Benz's Avatar
Quoted: 37 Post(s)
Sludge is from dino oil times. This is why you would have to be careful when changing from dino oil on a "historic car" to modern synthetic, quite like the concerns the original poster had.
Diesel Benz is offline
post #9 of 9 (permalink) Old 06-15-2009, 10:09 PM
Then I'm good.. Mobile 1 synthetic in my cars and Motorex synthetic in my motorcycles... The oldest car I've ever had is 10 years old, so I''m not much of a historic car guy I quess.
BBZLC is offline
    Sludge = New Engine ZenonZzyyzyk W203 C-Class 6 06-14-2008 07:04 PM
    E430 engine sludge problem dsl108 W210 E-Class 2 02-24-2007 11:52 PM
    Sludge on the cap of engine oil ismav W163 M-Class 6 02-10-2007 08:07 PM
    Engine with Black Sludge Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 15 04-28-2004 08:36 PM
    Toyota, Lexus and the Engine Sludge Problem. JohnN W163 M-Class 3 02-15-2002 02:39 AM
