Air Conditioner Intermittently Blows Hot - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-12-2009, 06:38 AM Thread Starter
Date registered: Jan 2008
Occasionally on my 2005 SLK 350, my AC starts blowing hot air. It only lasts for about 30 seconds, then cold air resumes. It happens 2-3 times every day. The dealer has had it twice, but can't duplicate the problem. Does anyone have any suggestions?
bruceste is offline
post #2 of 3 (permalink) Old 06-12-2009, 06:48 AM
Arn560's Avatar
Vehicle: 04 C230 Kompressor
If it does it in auto mode, maybe your interior temp sensors are dirty & it issending a wrong reading to te compressors to turn on & off. Try cleaning with a vacuum cleaner. In my car I have 2 sensors, one by the int. rear view mirror & the other on the HVAC control pad. Hope this works.
Arn560 is offline
post #3 of 3 (permalink) Old 06-12-2009, 12:01 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Plus one. Also check/replace your cabin filters, if they're dirty that can result in an inefficiency and inaccurate readings, as well as erratic behavior and shorter blower motor life.
Take care and enjoy the ride,
Greg
Check Codes is offline
    1998 mercedes 320, ml , a/c blows freezing cold air,then hot air bevleblanc W163 M-Class 14 11-27-2012 06:24 PM
    Blows hot air EagleRock W126 S,SE,SEC,SEL,SD,SDL Class 1 07-22-2007 03:00 PM
    AC blows hot air rwolak@verizon.net R/C107 SL/SLC Class 1 07-18-2006 02:40 PM
    Blows hot air only Jercedes W124 E,CE,D,TD Class 1 01-25-2005 08:20 AM
    A/C blows hot air first few minutes then turns to slightly cool air Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 8 08-20-2002 05:27 AM
