ASR, ABS, Instrument Cluster faults, Does anyone have similar problems - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-10-2009, 10:54 AM Thread Starter
Date registered: Jun 2009
Hi, I'm new to this site. looking for a bit of help...
I have a 2004 (54 plate) Vito 115 with an intermitent fault on the dash board, When driving along the motorway 60-70mph, the speedo, milomter and rev counter stop working, also lots of lights come on to suggest the engin has stopped, occosionally i also lose some power but can still keep the speed steady although it won't go any faster. I guessing there is an electrical fault somewhere... any ideas.
There is a second fault which may or may not be connected. The ABS and ASR stopped working sometime ago and the two lights on the dashboard stayed on, i eventually found a damaged cable which i repaired and the lights went off... all OK for 3 days. Then the lights came back on together with the red brake light.( all on the dash). But i can't find seem to find out why. MB suggest the ABS/ ASR controller/ pump thingy needs replacing, but there not certain... Any ideas.
Has anyone else had similar problems? Oh by the way, my vitos on 176,000 miles so i guess things are going to wear out.
123childre is offline
post #2 of 4 (permalink) Old 09-10-2009, 10:42 PM
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 199,xxx Miles
Quoted: 4 Post(s)
leapyfish is offline
post #3 of 4 (permalink) Old 04-06-2015, 03:05 AM
Date registered: Apr 2015
Hello Steve--read your problem details with interest,my daughter as just called me to tell os almost identical problems (Vito 05 plate)--could you let me know what the diagnosis was and what remedial action did you have to take--thanks martin r
martin ray is offline
post #4 of 4 (permalink) Old 04-06-2015, 12:46 PM
Date registered: Jul 2005
Vehicle: 90 300E, 99 ML430, 00 ML320, 05 E500 4matic Wagon
Quoted: 877 Post(s)
Hi Martin,
Steve has not logged in here since 2009.
My best suggestion would be to post your issue in our Vito section of the forums.
Cheers and welcome to the site.
Noodles is offline
    E320 Instrument cluster display faults NippyNelmo W210 E-Class 16 02-23-2015 08:40 PM
    ABS/ASR Instrument yellow Lights are on swestbury R129 SL-Class 4 11-01-2007 12:23 PM
    ASR/ABS problems Simen W140 S-Class 5 01-15-2006 05:58 PM
    ASR/ABS problems Simen W140 S-Class 4 11-19-2005 12:52 PM
    Instrument Cluster Problems gomez18 W126 S,SE,SEC,SEL,SD,SDL Class 5 08-05-2005 07:26 PM
