post #1 of 3 (permalink) Old 06-08-2009, 10:37 AM Thread Starter
Date registered: Jun 2009
Vehicle: Mercedes Benz 560SEL
Hello All,
I have a 90 560 SEL that has a gas leak along the seal of the fule distributor. Does anyone know whee I can get DIY instruction on changing this seal of give me some direction? This is a first for me and I want to do it right. Cannot afford to send to the shop right now. Also, can the relay on the side of the distributor leak as well. I ask because it looks as if gas is coming out around the unit and there is a pin hole in the middle of the relay and it looks as if gas is coming out of it as well.
Could a build up in pressure cause this to happen? If so, what is the most comon reason on this model? When I take off the gas cap allot of pressure is released and I want to be sure I do not have anything else going on.
Thanks for your help in advance.
Last edited by carolina560benz; 06-08-2009 at 10:44 AM. Reason: Needed to add info
carolina560benz is offline
post #2 of 3 (permalink) Old 06-08-2009, 10:49 AM
Date registered: Apr 2009
Vehicle: Current: 1987 560 SEC US, former factory trained MB tech 10 years, owner of 14 others.
As a recall, a seal kit is available for around $20. A forum search in 126 would be your best bet. Pressure in a tank is normal.
renaissance_warrior is offline
post #3 of 3 (permalink) Old 06-08-2009, 12:46 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 544 Post(s)
There is an o-ring at the bottom of the fuel distributor, which rarely fails. More common is a leak from the EHA (the black thing attached to the side by two screws). Check that out. It's also possible that you may need to replace the fuel distributor itself.
GeeS is offline
    fuel distributor question daryn R/C107 SL/SLC Class 44 02-06-2008 04:49 PM
    Fuel distributor question samgher W201 190-Class 0 10-08-2007 06:22 PM
    fuel distributor question mercedes84black W126 S,SE,SEC,SEL,SD,SDL Class 2 02-01-2006 04:02 PM
    Help ! Fuel distributor block question j chen W201 190-Class 3 07-14-2004 03:24 PM
    Fuel Distributor question 4benzes R/C107 SL/SLC Class 7 01-17-2004 03:47 PM
