Check Engine Light Code P0410/P0455 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-04-2009, 03:20 PM Thread Starter
Date registered: Oct 2007
I have an 2000 e320 and recently the check engine light came, haven't had any problems before coming on. After taking it and having the code read it came up with a P0455 and P0410. Any ideas thanks.
ptclink is offline
post #2 of 3 (permalink) Old 06-04-2009, 05:15 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hey, PT.
Please click the user cp link and complete your BW profile for vehicle and location as that is often useful information.
Also, you're up in the general forum but there is a forum specific to your chassis, the W210 forum, scroll down and you'll see it. It's quite active with lots of good folks and a slew of help/diy tips that are in stickies...including one for translating those pesky codes to something more meaningful.
The P0455 code is a perceived leak in the evap recovery system, quite often that is triggered by a failure to properly seat the gas cap, so check that out. If not then you could replace the cap (it's almost ten years old, you might be able to find a new gasket for it). Cleaning the purge valve would be next.
The 410 code is for the secondary air injection pump. That could be related to the evap code, so I'd first focus my attention on it, then clear codes and see if the AIP code returns.
Take care and enjoy the ride,
Check Codes is offline
post #3 of 3 (permalink) Old 06-04-2009, 05:44 PM
ohlord's Avatar
Vehicle: 1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
And don't
be in the habit of topping off your tank.
And pry out the gas cap gasket and apply a bit of vasoline and wipe it off and flip it over and re insert it into the cap.Gets you another ten years that way.
Then clear the codes and see if they come back.
00-02 drivers side self dimming heated mirror
17mm special spark boot tool
O2 plug and play sensors
16mm spring loaded swivel spark socket
trans dipstick and magnet
Mercedes Benz Lyrics
Artist(Band):Janis Joplin
"Oh Lord, won't you buy me
a Mercedes Benz"
"Follow Peace,center Life"
ohlord is offline
    Check Engine Light - Code P0410 kambakht R170 SLK-Class 48 07-19-2012 07:08 AM
    Code P0410, check engine light on Tibor's Benz W140 S-Class 3 03-13-2009 10:14 PM
    How to check code for check engine light 94 E320 W124 Synd W124 E,CE,D,TD Class 1 05-24-2007 02:37 PM
    1998 SLK-230 Engine Check P0455 and P0410 k_afshari R170 SLK-Class 4 04-09-2007 07:16 AM
    Check Engine Light ... P0410 UncAl W163 M-Class 6 09-08-2004 05:55 PM
